Why My Last Gasket Was Blown
Old 04-12-2013, 12:09 PM
rlm328
rlm328's Avatar
Default Why My Last Gasket Was Blown
A little preface. I had Darton MID sleeves put in a 3.0L block.
Finally got my head off to replace the gasket. The number 3 sleeve had slid down the machined pocket by 0.003". Now my question to every one out there is what are my options other than yanking it out and sending to a machine shop, which is the lowest in my desire list. Can I get away machining an O-ring in the head and using a wide fire? or are there less obvious solutions that I am overlooking.
Old 04-12-2013, 02:18 PM
blade7
blade7's Avatar
Who fitted the sleeves and what's to say that one or another wont sink again in the future ?.
Old 04-12-2013, 03:05 PM
blown 944
blown 944's Avatar
Is there even a wide fire for a 3.0? I've never looked. .003 is a stretch, but might be worth a try if the engine is still in car.
Old 04-12-2013, 04:07 PM
reno808
reno808's Avatar
who did the sleeves?
Old 04-12-2013, 05:41 PM
CyCloNe!
CyCloNe!'s Avatar
Norwood?
Old 04-12-2013, 05:52 PM
Thom
Thom's Avatar
Yes, readily available from Victor Reinz.
Old 04-12-2013, 07:42 PM
rlm328
rlm328's Avatar
The sleeves were installed by Darton-East, the east coast distributor for Darton. I have decided to go ahead and pull the motor and re-deck. I have a copper gasket I will install that is .050". Prior to decking we will press them all to ensure they are seated.
Old 04-12-2013, 11:28 PM
TexasRider
Late Porkchops
TexasRider's Avatar
I thought those sleeves were pressed in to begin with Bob , or no ?
Old 04-13-2013, 12:30 AM
rlm328
rlm328's Avatar
Yes they are a press fit, but if there was some swarf in the way it may have kept the liner off the seat. We will give them another chance to seat.
Old 04-13-2013, 12:32 AM
Dougs951S
Dougs951S's Avatar
Do you think the copper gasket will be more forgiving in the event that the liners shift again in the future?
Old 04-13-2013, 12:36 AM
rlm328
rlm328's Avatar
I'll keep everyone informed on the copper gasket. One of my advantages vs. a normal 944 block is that my liners do not allow as much cylinder movement.
Old 04-13-2013, 01:40 AM
TexasRider
Late Porkchops
TexasRider's Avatar
Maybe I will see you over around Sams sometime Bob. I will try to get over there next Saturday or so and see what they are up to.
Old 04-13-2013, 05:15 AM
Alpineace
Alpineace's Avatar
how is that?
also what block are you using?
Old 04-13-2013, 08:21 AM
blade7
blade7's Avatar
Are you letting the same outfit reseat the liners and if so what sort of goodwill are they offering ?.
Old 04-13-2013, 09:35 AM
333pg333
333pg333's Avatar
Originally Posted by Alpineace
how is that?
The MID's interlock at the top.
Quick Reply: Why My Last Gasket Was Blown
