Refresh951's Hybrid Ultra Stroker Build
#78
Interesting my new 103mm Cometic is different at the coolant ear than the last one I received from LR. On the 2.85L I had a leak here. Going to call Dave tomorrow at LR and discuss.
New Cometic HG:
Old Cometic HG:
Update: Dave at LR could not explain why the gaskets were different. He is looking into it. I am pretty sure the Cometic I bought a few months ago is an old design that is known to leak at the coolant ear. It was redesigned a few years ago to eliminate the problem but somehow I think I got an old one.
New Cometic HG:
Old Cometic HG:
#80
http://www.jepistons.com/Products/138103.aspx
On the 2.85L I used these:
http://www.jepistons.com/Products/148750.aspx
Notice the difference in pin height and inverted dome volume. If I build another 2.85L I think I will use a -16cc inverted dome like Sid did so that it would be a zero interference design.
This table was helpful in making decisions: http://www.jepistons.com/Catalogs/SR...0-400_inv.aspx
#86
Overall, I learned a great deal during the 2.85L build. On a stroker crank, I would make sure the crank is checked for straightness after the off-set grind and also check the thrust surfaces especially if the mains were turned. This should be done in addition to the normal stuff such as plasti-gauge measurements to check oil clearance on the rod and main journals.
#87
Coated rod bearings arrived from Modern Automotive Performance:
http://www.maperformance.com/acl-rac...l#.UNphRG-umIU
#88
