best way to clean engine block and parts?
Brake cleaner worked wonders for me to get the nasty stuff off. I was told that some one does Co2 blasting ? I understand that it brings aluminum to like new shine but I have no idea where it is done.
In the bay, brake cleaner, castrol super clean - brush. You can use a pressurized sprayer to keep the rinse water contained
![](http://gallery.rennlist.com/albums/Rhob/IMGP0440.sized.jpg)
out, pressure and aluminum brightener
![](http://gallery.rennlist.com/albums/Rhob/IMGP0448.sized.jpg)
![](http://gallery.rennlist.com/albums/Rhob/IMGP0449_001.sized.jpg)
complete, almost
complete, almost
![](http://gallery.rennlist.com/albums/Rhob/longblk.jpg)
good quality gunk cleaner + steam cleaner + glass blasting = brand new look. all inlets have to be properly sealed. I made a steel blanks for all openings (oil, water, air, exhaust) and just blast it with glass after brief cleaning.
You can do some parts, such as the balance shaft covers or sump separate, so long as you can visually inspect them to be absolutely clean after. Also depending on what media you are using it can be a porous finish(such as garnet) so even though its clean it will attract dirt quite quickly. Walnut/ glass or steel shot can give a different finish which may be more desirable.
Petrol a great cleaner, just be sure your in a ventilated area and your wearing gloves. Oh and no ignition sources.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I put it in a pump spray bottle, and went at it. I also used GUNK and warm to hot water, in a pump spray bottle ( I have a pressure washer, but it only does cold water ...)
I used Eagle One MAG wheel cleaner (the one that says "effective cleaning for rough cast alloy wheels") with great results. It's an acid, so like with the AC condenser cleaner, you have to be careful.
The downside is after a couple years, my block looked pretty much the same as it did (minus the grease/oil buildup).
Good luck
Regards
Ed
do you cover the bearing positions or bores?
Oh.... and bead blasting doesn't hurt either, if you have the stuff off the car ?
Thanks Tom![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Thanks Tom
EVOMMM (07-05-2022)
