best way to clean engine block and parts?
Old 10-15-2012, 04:20 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Default best way to clean engine block and parts?
which is the best way to clean the block and parts that bolt on to the block?
i used diesel and dabbed it on and got rid of most of the oil buildup and gunk everywhere but it's not as clean as i want it to be, is there any product that'll just rip everything off?
Paulyy is offline
Old 10-15-2012, 05:27 AM
DLS
User
DLS's Avatar
I used a pressure washer with hot water to most parts.
The block i sandblasted and painted
DLS is online now
Old 10-15-2012, 06:00 AM
Paulyy
Professional Hoon
Paulyy's Avatar
i was thinking about sandblasting, probably need to tape some parts up before i do like the balance shaft covers.
Paulyy is offline
JET951
JET951's Avatar
No offence DLS but sandblasting a block is a big no no. even if you block off the galleys sand will still get in there and it sticks on corners inside the block. even after rinsing and water blasting the sand/garnet can stay in there. possibly later become loose in the oiling system
High pressure water is fine though. Paulyy we have found petrol to be a better cleaner then diesel. Being a silicon alloy block they can come up fantastic when cleaned up.
JET951 is offline
Old 10-15-2012, 06:09 AM
Paulyy
Professional Hoon
Paulyy's Avatar
thats what i was afraid of, so i was sceptical do to my block with a sandblaster.. same thoughts.
never thought petrol would be a good cleaner, will try tomorrow. thanks!
Paulyy is offline
Old 10-15-2012, 06:14 AM
JET951
JET951's Avatar
You can do some parts, such as the balance shaft covers or sump separate, so long as you can visually inspect them to be absolutely clean after. Also depending on what media you are using it can be a porous finish(such as garnet) so even though its clean it will attract dirt quite quickly. Walnut/ glass or steel shot can give a different finish which may be more desirable.
Petrol a great cleaner, just be sure your in a ventilated area and your wearing gloves. Oh and no ignition sources.
JET951 is offline
Old 10-15-2012, 06:24 AM
DLS
User
DLS's Avatar
None taken
Yes sand blasting is maybe not a good idea but my block was in bad shape and i was really thorough when i cleaned it afterwards and i mean really really thorough
But for most people high pressure water will be enough so stay away from sandblasting the block.
DLS is online now
Old 10-15-2012, 06:30 AM
Ski
Ski's Avatar
I've used a pressure washer and aluminum brightener, like a party barge hull brightener and it comes out looking pretty good.
Ski is offline
Old 10-15-2012, 08:05 AM
xsboost90
Now Cool
xsboost90's Avatar
ive used some condensor cleaner for air conditioners - acidic so be careful, but its meant to safely clean aluminum.
xsboost90 is offline
Old 10-15-2012, 08:17 AM
Scott H
User
Could just drop it off at a machine shop and have it sonic cleaned.
Scott H is offline
Old 10-15-2012, 08:30 AM
Ski
Ski's Avatar
That's what I miss about living in the bigger metropolitan areas, choices.
Ski is offline
Old 10-15-2012, 09:41 AM
CurtP
Super User
CurtP's Avatar
I used Eagle One MAG wheel cleaner (the one that says "effective cleaning for rough cast alloy wheels") with great results. It's an acid, so like with the AC condenser cleaner, you have to be careful.
The downside is after a couple years, my block looked pretty much the same as it did (minus the grease/oil buildup).
CurtP is offline
Old 10-15-2012, 09:51 AM
Paulyy
Professional Hoon
Paulyy's Avatar
thanks guys for the tips! i'll try petrol (your 'gas') and see how it turns out, if not so good i'll buy some of that acid but i think i might have some laying around.
Paulyy is offline
Old 10-15-2012, 10:49 AM
txhokie4life
User
txhokie4life's Avatar
What your options if its still in the car?
I pulled my turbo -- but that whole side of the engine is a mess from repeated oil leaks
and popped dip sticks.
I was thinking of simple green and some brush action as best I can get in there.
thanks,
Mike
txhokie4life is online now
Old 10-15-2012, 11:33 AM
Hacked 987
Hacked 987's Avatar
40 cans of brakekleen and a few donor brain cells.
Hacked 987 is offline
Quick Reply: best way to clean engine block and parts?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
