TonyG > New Race Car Build Thread
#946
Everyone... that's for the words of encouragement. And yes... the engine is probably the least expensive part of this project.
That said... :-) since I'm there now .... and because a set of pistons and rods cost the same no matter the engine displacement :-) It looks like I'm just going to build a LS3 short block at 6.2L vs the LS6 at 5.7L and pick up some power along the way.
Using my same CNC'ed LS6 heads, we're going to open up the valve sizes and unshroud the vavles picking the compression up with the piston.
We've plotted it on the computer and there are substantial power gains to be had going this route.
So there it is.... gonna order the parts today. Should have it back together in a couple weeks.
TonyG
TonyG
#947
Tony, you might want to look into a 383. I've been looking into built short/long blocks for the past month or so. A 376 costs the same as a 383, check out Texas Speed and Thompson Motorsports. I'm probably going to get a built long block from Thompson...
#948
What size valves are you running?
#949
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
prepped LS7 short block w/ forged.... $5,949.87
https://sdparts.com/details/scoggin-...er/sdls7sb427d
#950
Thats a bum deal Tony. At least its a chance to upgrade.
Maybe something like this would help somewhat? Remote filter mount that has a built in primping pump that you spin with a drill.
http://www.petersonfluidsys.com/filter_mount.html
#951
With a bigger budget, I think the LS3 6.2L with ported LS6 heads sounds like a great way to go. Cool how we can mix and match these engine parts, isn't it?
#953
Ug, so sorry Tony. Keep your eye on the prize though. Given the extent of your build, a blown LS motor is just a flesh wound -- practically a consumable. Hang in there and add a little HP while you're at it....
#954
Rennlist Junkie Forever
*** Update ***
The parts are ordered. Just dump another wad of cash.
The beauty of engine building these days is that if you have the right software, and all the correct data, you can fully design the engine on the computer and know within a few HP of exactly what you'll have.
Given this, we spend a couple hours on the computer designing the engine. Here's what we came up with:
LS3 stroked to 398cu in or 6.5 liters.
We didn't go bigger on the stroke because of how much the pistons hand out the bottom of the bores (even on a stock LS3). The opinion of the engine builder is that on a race engine the block would need to be sleeved to get the support necessary to go bigger reliably. And at that point you might as well use a LS7 short block $$$.
So that's where it is. A 398" LS3
The crank and rods are Callies 4340 forged pieces. The pistons are Ross forged pistons. A high flow oil pump is also getting installed.
The already CNC'ed cathedral port 243 heads are going to be opened up further (slightly) on the ports, the FAST 102 intake is getting ported to match, the combustion chambers are getting opened up to the larger bores, and larger light weight valves are getting installed.
The valve spring, retainers, rockers, and cam stay as-is, although the cam timing will be changed.
The previous LS6 made 461RWHP peak and 400RWTQ peak. Based on the computer simulations we should pick up a solid 50-60HP over the previous setup with more torque everywhere, but especially at the critical 3500-4000 rpm mark.
Parts are rolling in now and should have them all by Monday. Then another week to machine, put together and install.
Stay tuned.....
TonyG
Stay tuned.....
TonyG
#956
So nobody's putting their hand up to accept any blame for the engine failure?
#957
Which software?
#960
