TonyG > New Race Car Build Thread
Old 09-12-2013, 09:40 AM
  #736
V2Rocket
Rainman
V2Rocket's Avatar
well, at least you know your 944 can tow your truck should the f150 break down..
Old 09-12-2013, 09:51 AM
  #737
Duke
Duke's Avatar
While the V8 powerband is hard to beat, 400 ft lb is much lower than a 3 liter turbo produces.
Old 09-12-2013, 10:49 AM
  #738
fwb42
fwb42's Avatar
Tony, Did you ever follow the post by member "Dfastest951' about having custom R & Ps made? He's in Vegas and has the 190+ street car. Might help.
Old 09-12-2013, 05:19 PM
  #739
IanM
IanM's Avatar
Is that plot at the wheels or the crank? I assume at the crank. Over 300 lb-ft at 2500rpm is very nice. That thing should pull hard out of slow corners.
The two things I like most about tracking my GT3 vs my ex-951 are the better drive out of slow corners in the GT3 (even though peak torque is much lower) and the taller gears and 8200rpm redline allowing me to hold gears much longer. Sounds like you have both those areas covered.
Old 09-12-2013, 10:46 PM
  #740
TonyG
Rennlist Junkie Forever
TonyG's Avatar
That's at the wheels. Not at the crank
TonyG*
Old 09-12-2013, 10:48 PM
  #741
968ls1
968ls1's Avatar
That is RWHP!
Old 09-12-2013, 10:52 PM
  #742
TonyG
TonyG's Avatar
[QUOTE=Duke;10755372]While the V8 powerband is hard to beat, 400 ft lb is much lower than a 3 liter turbo produces.[/QUat theOTE]
But the LSx engine will live longer. And runs on 91 octane pump gas.
No matter... If I were to stay with a LSx engine, it would be a much larger engine that will make over 600tq and 650hp at the wheels on 91 pump gas.... From 2500-7000+ rpms
We now have plans for a 496cu inch LS7
TonyG
TonyG
Old 09-12-2013, 11:03 PM
  #743
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Originally Posted by TonyG
We now have plans for a 496cu inch LS7....
Old 09-12-2013, 11:29 PM
  #744
333pg333
333pg333's Avatar
[QUOTE=TonyG;10757344]
TonyG
TonyG
Not big enough!!!
Old 09-13-2013, 12:31 AM
  #745
TonyG
TonyG's Avatar
[QUOTE=333pg333;10757440]
Not big enough!!!
The cool thing about the LSx platform is that the engines are basically the exact same physical size externally.
A 350 (5.7L) is the same outside dimensionally as a 496 cu in engine.
So it's a straight bolt in affair.
Plus everything externally bolts straight up.
So it's essentially a long block swap.
TonyG
Old 09-13-2013, 01:46 AM
  #746
Reimu
Reimu's Avatar
What happened to the Porsche v8 idea
Old 09-13-2013, 02:27 AM
  #747
TonyG
TonyG's Avatar
A Porsche V8 was never in the running.
The only Porsche engine that we are considering is the 2014 Porsche Panamera twin turbo V6.
It's that or the LSx.
It's clear which is more reliable.
And it's clear which can make more power over the long race.
But the Porsche engine is lighter and can move the CG of the engine back behind the front axle. So it gets the nod for handling.
And the Porsche engine is Porsche. That would make the car pure Porsche. Which is a good thing.
But when it comes to racing... you just can't beat the compact light weight LSx V8 for performance.
$25K can buy you reliable, pump gas, light weight, power like no other... that will do 3-4 seasons without a rebuild.
So there it is....
TonyG
Old 09-13-2013, 02:56 AM
  #748
333pg333
333pg333's Avatar
Damn your logic, damn it to hell!!!
Old 09-13-2013, 04:36 AM
  #749
Duke
Duke's Avatar
It is indeed hard to beat the logic behind the LS-engine. But logic also tells me I should have gotten a 996 Cup instead and have more spare time and more money to spend elsewhere. Damn it, damn that logic to hell!
Side note. Cost and reliability aside, a 3.0l 16v turbo engine is fantastic to drive and beats pretty much any LS engine except a high end worked machine. (Comparing torque at 2500 rpm is just meaningless for a track car.)
Old 09-13-2013, 08:40 AM
  #750
TonyG
TonyG's Avatar
That's great except for the small detail that the engines need to be rebuilt ever 30 hours (which is about one full season of track time). The cost: $22k USD if you don't blow it up/badly over rev it.
You have no ideal how many friends I have that go through this every year.
And... don't forget about the sequential trans. That too gets serviced to a tune of close to $15k every season and a half +/- depending on how you shift.
And.... last but not least... racing fuel at $10/gal (vs $4/gal for pump), there's another $4000/year in fuel costs.
So say... an additional $40k per year to run the Cup Car over what I've built... which is... btw... why I built my car in the first place :-)
There are several tracks that have slow turns where I come out of the corner at 3000rpms (in order to stay out of 2nd gear). This is what gives me that advantage over a Cup Car with a sequential box and the only thing that saves me. They have to shift... I don't.
If I had a regular H pattern trans and had to shift, they would kill me just in the time it take to shift.
Once I put in a 496 LS7 with over 500ft/lbs at 3000rpms... it's gonna be bad news for them when I pull out of the turn at 3000rpms and pull to over 7000rpms w/o shifting.
TonyG
Quick Reply: TonyG > New Race Car Build Thread
