Refresh951's Hybrid Stroker - A Blown944 Design
Old 10-25-2012, 10:49 PM
  #256
blown 944
blown 944's Avatar
Good work. You do need to start your pulls earlier in the rpms though. You're changing your curve dramatically starting so late. I meant to say something before but...
Anyway, seems to be getting better every time. Just like my year. Pretty amazing combo if I do say so myself.
Old 10-25-2012, 11:08 PM
  #257
refresh951
refresh951's Avatar
Thanks Sid. I think the difference in the curve shape is due to settings in the EBC. Still messing with the gain. I don't think I was clear that the graph shows a pull from a few weeks ago with MBC and a pull from tonight with the EBC.
Old 10-25-2012, 11:17 PM
  #258
blown 944
blown 944's Avatar
I'm looking at the two most recent pulls. Looks like the latest starts later in the rpms. I noticed that if you start earlier, around 2200, that the torque escalates much sooner.
I noticed this on yours and mine as well.
Old 10-26-2012, 01:43 AM
  #259
mudbuddha
mudbuddha's Avatar
Nice numbers Shawn- not as crazy as Sid's but still a hoot to drive on the street I'd imagine. You'll like it even better at 21lbs.
Old 10-26-2012, 02:09 AM
  #260
V2Rocket
Rainman
V2Rocket's Avatar
Interesting on the overlay. The peak power increased almost perfectly in proportion with displacement increase, but the curve is undeniably improved across the range. Nice!
Old 10-26-2012, 12:57 PM
  #261
User 52121
User 52121's Avatar
Originally Posted by refresh951
Went back to the dyno tonight to get my EBC setup right. Squeezed a bit more power out and cleaned up the curve on top. The graph below shows an 18 psi run from a few weeks ago with MBC and a run from tonight with the EBC. A bit more work to do getting the gain set right for bottom end power. No real point in me pushing much past 18psi as the turbo runs out of steam for sure.
Also, Jim asked for an overly of the 2.85L Stroker dyno with my old 2.5L so I had Arthur at DynoLab plot it for me. Here it is. Both runs were 18 psi and both runs used MBC:
THanks Shawn! THis is now another one of your threads I will have bookmarked
Pretty interesting to see how similar the curves are between the two. Just "more" really.
Old 10-26-2012, 02:00 PM
  #262
V2Rocket
Rainman
V2Rocket's Avatar
So you've hit your 400RWHP/TQ goal, but still some massaging to due...how is your tune?
Old 10-26-2012, 04:08 PM
  #263
DanaT
DanaT's Avatar
Are those dynos on E85 or on pump gas?
Old 10-26-2012, 06:20 PM
  #264
refresh951
refresh951's Avatar
Really not a lot of difference except displacement. I also added the bigger valve head but I do not think I am taking advantage of it with my current turbo. Sid's motor has shown that the stock head flows pretty well.
Not much to tune. Everything is spot on thanks to Rogue. This is the end of the line with the current turbo. I am researching turbos and will be making some changes.
E85
Old 10-26-2012, 06:27 PM
  #265
V2Rocket
Rainman
V2Rocket's Avatar
E85
FRF VNT
Old 10-26-2012, 06:50 PM
  #266
blown 944
blown 944's Avatar
Shawn, mine is only stock valve size. There is a bit of work done.
Looking forward to your turbo choice!!
Old 10-26-2012, 06:56 PM
  #267
User 52121
User 52121's Avatar
You've got a PM coming...
Old 10-26-2012, 07:10 PM
  #268
refresh951
refresh951's Avatar
Shawn, mine is only stock valve size. There is a bit of work done.!
Sid, with you I use "stock" in the loosest sense of the word as nothing on your car is "stock"
Old 10-27-2012, 01:27 PM
  #269
White_951
White_951's Avatar
Sorry if this has been asked before....Aren't you currently running a 60-1?
Old 10-27-2012, 02:42 PM
  #270
Zeff
Zeff's Avatar
Shawn has a dbb 50trim with a #8 if I remember correctly.
Quick Reply: Refresh951's Hybrid Stroker - A Blown944 Design
