Rogue Tuning: DME tuning, logging, and diagnostics
Small Business Partner
Much more than just adjusting AFR...
AFR, timing, tip-in enrichment, rev-limits, idle-speed, drop-throttle response, overboost limits, warm-up enrichment, cold-start enrichment, warm-start enrichment, intake air temp adjustments, coolant temp adjustments, injector-duty-cycle limit adjustment, ect, ect, ect.
This setup works intimately with the M-Tune. Pricing I will post up this week, and setup should be available immediately afterwords.
Excellent work Josh, I'm looking forward to this becoming a finished product. This will save a ton of hassle and make on the fly tuning a no brainer. I shot you an email/pm bout a week back josh; this changes the game for me considerably. Keep us posted.
Joshua,
No mention of logging knock. Is this possible given the KLR is a separate system in the 951? Perhaps it could be easily adapted to the S2 M-Tune when this appears? I would imagine that knock logging would be even more of a game changer - it is something that the Zeitronix and Inniovate cannot do (well they can't log timing either!).
Brian, did you watch the youtube videos?
Joshua,
The S2 setup we will see, being that the S2 is a bit more integrated (one ECU), it might be an easier solution to log knock.
You will need TunerPro:
TunerPro download
To datalog, you do not have to register the software. To tune, you will need to register ($40 - not to me, but to the author of TunerPro).
Next, you need to download the package I've put together:
DME Interface Package
Unzip the package, and put the contents somewhere you will remember.
Now, install TunerPro. Once the software is installed, we need to set it up for use.
First, open the .xdf file:
Navigate to where you put the unzipped files, and select the .xdf file. Once you do this, you will want to make sure the "Parameter Tree" is showing:
If it isn't showing, press F6, or select 'View' -> 'Show Parameter Tree'. Once the parameter tree is showing, click on the pull-down menu right underneath where it says Parameter Tree:
And select 'Parameter Category'. It should now be nicely organized like in the pictures.
Next, we need to load the .bin file:
Again, navigate to where you put the unzipped files, and this time select the .bin file.
Finally, we load the datalogging file:
Navigate to where you put the unzipped files, and select the .adx file.
Now, you will want to have the 'Parameter Comments' window, as it will explain what every tune-able option does. To get this window, press F10, or go 'View -> Parameter Comments'.
Finally, to show the datalogging screens, you have three options, the Dash ('Acquisition -> Show Dash'), Monitors / graphs ('Acquisition -> Show Monitors'), and Item Lists ('Acquisition -> Data Lists').
Now you can open any of the parameters in the Parameter tree, double-click on a table / value, and make changes, or simply read about what it does:
Once you setup the software, then it will remember your settings.
Truly amazing work Josh and very impressive... Now I'm looking forward even more to get the M-tune installed in my car, and be able to play around with all these new features..
I can hardly wait to see what else you have in the pipeline for our cars..
Thanks..
Thanks..
So, I wanted to show everyone an example of how useful the logging / diagnostic portion is...
We just replaced Sid's engine (thread here). We noticed it was running rough, and was a bit hard to cold-start.
So, we hooked up the laptop, and saw this:
At this point the car had been running for less than 5minutes. The problem is immediately obvious: the coolant temp was reading 261°F (127°C) !!!
We knew right away that the engine could not be that hot, so after inspecting the wire, we found that the wire inside the boot had frayed, and was shorted!
What could have taken a significant amount of time to diagnose and test, took mere seconds with the logger!
