cep fuel rail install
I'm having one put on my car today and have only seen it installed with a remote fuel regulator ,is that the only way?anyone have any pictures?
Thanks for any help.
It can be done with a 'saddle adapter'. I think Dave offered one as an optional 'add-on' for the kit, but you can purchase one that will work with it.
This is basically the same thing, and compatible with the stock FPR.
http://www.bahnbrenner.com/vw_audi/p...il_FPR_Adapter
Here is the above product mounted on my car with the CEP rail. Line routing is a mess as this was for test purposes, but you get the idea.
or with an adjustable regulator..
Not rocket science, but is bolt on....
Rocket Scientist
If by pile up of stuff you mean the AN fittings/lines and fuel pressure regulator, then yes. Obviously the rail, mounts and dampner are all custom built. I think Lindsey has updated their old fire starter rail with 4 legs now so the only difference between the two is how they look and price. Lindsey might still have NPT fittings too, which I don't care for but they might have changed that by now too. The rail is a nice replacement if the stock one is old and leaking and if you want an adjustable FPR like the Aeromotive one in the pictures.
Both the LR and CEP rail are very nice parts. Here is a little comparo between the two as i have used both on my car.
With that said the LR rail is a bit longer and can be a bit trouble some to mount due to space constraints between the end of the fuel damper and the firewall (wireharness, vacuum lines..etc are all there). The LR rail also still uses NPT ports on the rear for the damper adapter aswell as the inlet fitting. The CEP rail uses ORB fittings on everything. The LR rail is slightly lower profile (marginally) so more clearance with a strut tower bar. But both the CEP and LR rails are so much lower than the stock rail its a moot point.
The LR rail also lets you change around the injector harness routing a little. It is designed so spin the injectors around 180 degrees and have the injector connectors on the intake side.. see my pictures for reference. The other thing is the mounting legs on the LR rail are non adjustable. In my opinion this kind of a moot point also.
LR rail on my car, you can see the damper is pretty squished against the bundle of wires / vac lines.
CEP rail on my car..
Much more space between the firewall and damper
Much more space between the rail and strut bar (KLA) now. Note, the round portion you see is the damper all the way at the back of the rail.. the actual top of the fuel rail if you look closely is basically the same height as black fitting at the front. Mind you this is with brand new engine mounts also, so engine height is as high as it will go.
And the two rails side by side. Note i am using a different damper on the CEP rail in these pictures, but you get the idea.
Both fuel rails are really nice parts. I preferred the damper on the LR rail personally (made by Marren). But the ORB fittings on the CEP rail give me more peace of mind than NPT. The length thing is not a huge issue, i just had to play around with the routing of the negative battery cable and rearrange some vacuum lines.. but it can be a tight squeeze. Mine was a special case i guess with the extra stuff i have running across the firewall (Iceshark cables..etc). On a stock car it is a non issue probably. The difference in injector harness routing is up to you which you prefer. My main gripe with both rails is the lack of provisions for injector clips. So when pulling the fuel rail, unless very careful it can be a mess. Or you can do something like this to drain the rails.. Disconnect the return line and blow through it to push the fuel out the feed.. .
Is it noticeably noisier? I've heard that there will be louder pulsing sounds with a billet rail. I've had a new CEP rail kit sitting in a box for a year and a half now, STILL waiting for me to install it.
Rocket Scientist
Great explanation, Jon. If I could have it my way, it would be ORB ( O-ring boss) fuel in and ORB fuel directly out the back. No dampner. Much simpler, less risk of leak. However, Dave and I have argued that one to death.
I had a first gen (?) LR rail but swapped it for a stock rail as I got tired of the ticking noise at idle, even with the Marren fuel damper on, and couldn't stand the blue/pink colour scheme anymore on an otherwise stock-looking engine.
Jon, have you been able to notice any difference in noise with either units over the stock fuel rail?
There was some extra taping / pulsing i noticed at idle and when backing out of my driveway. Its not really all that loud, but noticeable. My car is pretty loud though, so i may be missing more. This is with 72lb Deka injectors.
