Hybrid stroker project
#106
What clutch/pp have you been using Sid?
#110
Patrick, it is a Spec pressure plate using one of Dnovak's feramic 6 pic discs. It is a bit grabby, but it is holding and that is all I care about now. Dave will have a clutch setup available soon that uses the stock PP (reworked) and this disc. It should be able to handle most power levels. We'll be testing it out on his car soon.
#112
I imagine that fuel is a big part of why you can run such high compression with boost on these motors with success, with a smidge extra help from the mile high air. I suspect it wouldn't last too long on California's anemic 91 octane. You'd think California would embrace E85, but the closest station to me is still miles away.
#113
#114
#115
There is no doubt it is the top reason I have had luck with high boost and compression. This engine however is only 8.5:1 so it isn't much of a challenge. It also helps that Josh can tune everything to work properly.
