HELP!! First Drive after rebuilt and This Happens! Major Crack in Tower
Old 03-11-2012, 09:53 PM
  #31
Bri Bro
Bri Bro's Avatar
Lart, That is a very nice gesture.
Old 03-11-2012, 10:09 PM
  #32
J1720
J1720's Avatar
Lart has been good to me during this rebuilt
Old 03-11-2012, 10:13 PM
  #33
zerMATT951
zerMATT951's Avatar
I'll second that - Lart is a good guy to have around when you're undertaking a major project and need bits and pieces that simply don't need to be "new". What would we do without him, or guys like him like Josh B? They are doing our community a huge service, not only by having the parts we need, but they ship quickly so we don't have to wait long when we get in a jam.
Old 03-11-2012, 10:20 PM
  #34
J1720
J1720's Avatar
Old 03-11-2012, 11:46 PM
  #35
jc in rb
jc in rb's Avatar
here's to Lart.
Old 03-12-2012, 06:04 PM
  #36
J1720
J1720's Avatar
I pulled off the tower today. I found a cam bolt bent into a L shape floating around. It backed out of one of the holes.
I should get Lart's tower by Friday
Old 03-12-2012, 09:28 PM
  #37
J1720
J1720's Avatar
Photo of bolt
Old 03-12-2012, 09:38 PM
  #38
carlege
carlege's Avatar
i bet it wasnt bent before it was flung into the cam housing. Gotta check those bolts man.
Old 03-12-2012, 09:56 PM
  #39
J1720
J1720's Avatar
I must of not torqued that one
Old 03-12-2012, 10:00 PM
  #40
carlege
carlege's Avatar
might not be a bad idea to go through all of the bolts and make sure you got them.
Old 03-12-2012, 10:08 PM
  #41
J1720
J1720's Avatar
I got all of them. Just need to wait for the new tower from Lart and I can button it up again, adjust the belts and cross my fingers
Old 03-12-2012, 10:50 PM
  #42
FBIII
FBIII's Avatar
Pull the plugs and pressurize each cylinder. If you bent a valve you'll hear the air escaping.
Old 03-13-2012, 11:37 AM
  #43
J1720
J1720's Avatar
Good idea! I do not thing the valves would have been affected, but worth testing.
Old 03-13-2012, 09:49 PM
  #44
Black51
Black51's Avatar
One little tip for the future is to dip your allen key in some a little engine oil; I pour a bit into the cap and keep it handy. This keeps the bolt and washer from slipping off the key and into the cam box.
Also put a little oil around the threads and washer. That way, the bolt has a better chance of slipping all the way in without getting caught up on some crud and seeming like it's tight. Plus it'll be easier the next time you need to back those bolts out.
Old 03-13-2012, 09:52 PM
  #45
J1720
J1720's Avatar
Sounds great! Thanks
I been useing a little grease in the top to hold it in place as I lower it in the tower. But I like the oil idea!
Quick Reply: HELP!! First Drive after rebuilt and This Happens! Major Crack in Tower
