How Much Boost Are You Running?
Old 06-11-2003, 04:30 PM
Porscheman101
Porscheman101's Avatar
Post How Much Boost Are You Running?
Im just curious at how much boost are our cars are running. Mine Seems a little low. I am running about 14 psi with Huntley Stage 3 MAF, Stage 2 performance chips, free flow exhaust, lindsey boost enhancer, shimmed wastegate, remote crankcase breather, ignition upgrade and a rebuilt turbo.
I took off the boost enhancer and I was only running 12 psi full throttle. I went through all of my vacuum hoses ect... and didnt find any leaks.
Any ideas?
Old 06-11-2003, 04:37 PM
Luke
Luke's Avatar
Post
13psi.
Old 06-11-2003, 04:53 PM
Porscheman101
Post
ok, so i guess im not to off base here.
Old 06-11-2003, 05:07 PM
Jake951
Jake951's Avatar
Post
I'm set up for 15 psi peak, but I only see that in 4th and 5th gear. I get slightly less, about 14 psi, in 2nd and 3rd. I run the stock K26/8 with a shimmed wastegate.
Old 06-11-2003, 05:13 PM
Mike S
Mike S's Avatar
Post
15psi, guru chips, stock turbo
Old 06-11-2003, 05:30 PM
streckfu's
streckfu's's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Porscheman101:
<strong>Im just curious at how much boost are our cars are running. Mine Seems a little low. I am running about 14 psi with Huntley Stage 3 MAF, Stage 2 performance chips, free flow exhaust, lindsey boost enhancer, shimmed wastegate, remote crankcase breather, ignition upgrade and a rebuilt turbo.
Any ideas?</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">You boost is fine if you are using the stock turbo and wastegate. Normal for the 86 is 12 psi and you can get up to 15 with the LBE depending on condition of the car. Since you have the shimmed wastegate and the boost enhancer you MAY have a small leak somewhere but I doubt it.
Old 06-11-2003, 05:33 PM
streckfu's
streckfu's's Avatar
Post
13 psi in 3rd and 14 psi in 4th by the way.
Old 06-11-2003, 06:03 PM
Porscheman101
Post
Thanks guys. I was starting to worry that i might have to track down another leak. I still might have an exhaust leak, but im sure its nothing to big i cant fix.
Thanks Again
Old 06-11-2003, 08:39 PM
pk951
pk951's Avatar
Post
15psi tial wastgate 35mm k26/8 94 octane
Old 06-11-2003, 11:42 PM
shortyboy
shortyboy's Avatar
Post
hmm this is interesting, with all the mods done to your cars i thought u ppl would be running higher boost.well i learned something new today.
Old 06-12-2003, 01:43 AM
adrial
adrial's Avatar
Post
Shortyboy, the stock turbo is capable of 25psi+ of boost...that doesn't mean you're actually making more power at those levels though. Or that its anywhere near safe.
Old 06-12-2003, 02:47 AM
DanD
DanD's Avatar
Post
I run between 15psi and 18psi. With the stock k26 turbo the boost falls off to about 12psi near redline. Oh, and I'm changing my headgasket, big surprise.
After the headgasket and hopefully minor engine overhaul, I'll probably run the same unless I can find a deal on a bigger turbo. In that case, I would back down to about 15psi and still make more HP, but now all the way to redline.
Water injection is installed and ready to roll.
Old 06-12-2003, 07:12 AM
86944turbo
86944turbo's Avatar
Post
Low boost 1s approx. 10 lbs., for pump gas.
Med. is now 17.5.
High is 19-20. I'm trying not to use this much. That's why I raised med.
Med. & High Sunoco GT-Plus only.
Old 06-12-2003, 11:07 AM
Douglas_T
Douglas_T's Avatar
Post
Interesting posts!
Old 06-12-2003, 11:21 AM
clubracer6
clubracer6's Avatar
Post
What I picked up my car it was running 22-25#'s. I immediately asked the seller to show me how to turn it down. I run around 17# now. On another thread everone said I was crazy and would melt pistons. We have the head off now and the cylinder's and head itself look gorgeous considering the 100k+ miles on it. The turbo is also solid and it showing no signs of going. I'll probably play w/20 something again soon. I just need a limited slip now to get off the corners better.
Quick Reply: How Much Boost Are You Running?
