Track plans for 2012?
#61
I will finally fit my rear wing next year which I have had sitting at home for a year or more. It's one built for the TVR Sagaris GT cars. Nice piece, but has very close together mounting posts which has caused me to scratch my head a bit for a mounting solution.
Will be interesting to see how it affects spring rates. I currently run 1200F/1100R which has worked well with race slicks and the smooth Dubai tracks, although even with the stiff front end it can still be a bit loose in the rear once tires go off. (see my avatar pic!) Be interesting to see how the wing changes the balance of things.
The hood vents on my car are still in the same place Pat. White by itself does look all squeeky clean, I know, but I hope it will look better when I get some colour on it! I planned it as a blank canvas to allow for any choice of colour scheme graphics to suit sponsors etc.
#62
How about something like this for the wing mount?
http://s801.photobucket.com/albums/y...Porsche%20951/
#63
Its an idea I have looked at, but I'm not a real fan of mounting to or through the rear panel. I don't like the look much plus the rules in a lot of categories require you to keep the wing within the confines of the existing body limits meaning the wing needs to be further forward. I'm thinking more of building a frame across the rear hatch space tied into the rear chassis rails to mount to. My rear floor is cutout and I have a cover panel over a gearbox cooler I need to be able to access, so I have limited mounting points on the floor.
#64
I don't really like that look either.
A wing off a GT3 Cup has the mounts close to the same spacing as the rear frame rails. Thats what I used and it makes it simple to go straight thru a lexan rear hatch to the rails.
#65
Rennlist Junkie Forever
There are two uprights in the hatch area that bolt down to the frame rails. These extend up and butt up to the lexan hatch.
The wing mounts to the 4 bolt bosses (2 on each upright) through the lexan hatch to the uprights which are bolted to the frame rails.
TonyG
#66
Yes I know what you mean. Only problem is I didn't think about the wing mounting when I set up the gearbox cooler and pump. The cover pretty much takes the entire width of the floor behind the gearbox so I just need to make the frame with very wide floor mounts and narrow enough I can still remove the access panel on the floor with the wing off.
Another idea was just to weld in a braced flat panel across the top of the hatch opening at the rear sort of like below and mount the wing to that. The downforce would then be transferred into the chassis through the top of the hatch opening without the need for any attachments to the floor or rails. But I am undecided if the mouth of the hatch is strong enough to support a frame by itself?
#67
Thanks guys still trying to decide on the wing. There's a part of me that loves a stock looking 944 T kicking butt on all the crazy wing BMW's, but then there is the part of me that knows I will be faster with one.Since my motor is basiclly stock with a really good tune and exhaust I am under power for GTS-3 or over weight however you look at it.
#69
Go figure.... I wonder if there is anybody here with wind tunnel experience, etc... we could ask.
TonyG
#70
It shoulde be an easy enough question for an aerodynamacist to answer.
My thoughts (as an amateur) are as follows:
For a wing to work you need to accelerate the air under the wing since that will create a lower air pressure compared to the slower moving air above the wing.
Now the modelations I've seen show a very turbulent flow at the tip of a car. Using a spoiler, like the stock 951 spoiler, will direct the airflow upwards and will keep the airflow more stable and faster. This should increase the air velocity under a wing and hence give better downforce from the wing.
#71
#72
The air needs to be smooth and close to both sides of the wing in order for the wing to work properly.
TonyG
#73
I think the wing height has a big influence on the effect of the rear spoiler. Daytona prototypes run a little gurney on the bodywork underneath the wing. For the 944, I think a little >1cm wicker on the edge of the hatch could help (especially combined with a rear diffuser) and not interfere with the wing too much.
#74
I will possibly have to mount my wing something similar to the one on the Orange car, but will also need to mount it within the outline of the car (when viewed from above) as Steve mentions. I am not sure if the actual uprights need to be 'inboard' though? I was working on the premise of the elements only having to be inboard.
I regards to having a main wing working in conjunction with a smaller body mounted one, I was advised that this was a good idea by Simon McBeath (DJ Engineering) however he may not have been discussing the stock rubber sized one. The small snub tail thing that I have now may have been what he was looking at. In the not too distant future I will re confirm with him as we're getting closer to that point of mounting it.
#75
Just look at the pro teams using factory bodied cars.
You won't see that on any of the AMLS BMW, Porsche, Chevrolet, teams... and yet every one of those cars runs a big wing on the back.
There's a reason for that.
And trust me... when you get a real wing on the car.... it will provide more than enough down force even at a very shallow angle.
TonyG
