SPEC, KEP or South Bend?
Excellent!
Talking to SB now about the rebuild/relining.
I am in the middle of a 2.8 swap with my Super 75 and 18-20psi, Rogue tuned, etc. and will be north of 450wtq and currently running stock PP and Cup disk which has held fine for my current set up; about 350-360wtq.
But I am sure and being told I will need more than that for another 100 tq give or take.
Are you going to resurface the cup disk? If not I may be interested in it.
Drive-by provocation guy
For what it's worth my SB clutch has held up fine so far, at least as far as I can tell. Full season of AX with two drivers (and I won the season overall for my PCA region so I don't exactly tip toe) plus 4 DE's. For the price I'm definitely satisfied.
Oh, and my new stock 951 pressure plate won't hold at full boost around 4,000 rpm in 4th and 5th gear. It slips a bit then catches... not a good feeling. From that thread and advice on a few phone calls, I came away with the impression that the stock PP could hold close to 400 HP. Apparently that is not true as I don't think I'm even at 350.
What really erks me is that the clutch did fine on a Sunday flogging of 200 miles with racerxrick and Ryan chasing me and the clutch felt fine. The a week or two later, I start to feel it slipping.
Live and learn...
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Are you sure you are not getting tire spin? Weather is colder, less grip on the tires. Its been my experience that once a clutch starts to slip, you need to back off a bit to get it to stop. What disk do you have?
Well, I guess I do lift a bit when it happens, then I can get on it again after 4,500 or so when it hooks up. It's not wheel spin, it's the clutch. I even smelled once when I stayed in it too long trying to get around some cars. The disc is a Sachs 930.
Well, if you can smell it then it is the clutch. Strange, I ran that setup for years with no issues at up to 18 lbs boost. Any leaks from the rear main and did you resurface the flywheel??
I run a centerforce clutch with 340 rwhp and love it. No slip and clutch pedal effort is slightly above stock due to the unique centrifical weights on the pressure plate. Check out their web site. Centerforce rates my clutch to 700 hp. After all a clutch job on a 944 is one of my least favorite jobs.
My fairly new stock clutch started slipping right around the 350rwhp mark. Find an uphill grade on the freeway and try full boost in 5th -- if it's going to slip, that will tease it out.
I've tried a spec disk, and had bad luck with it -- way too much chatter and shudder for a street car, although I'm sure it depends on the type of material you use.
I currently have a South Bend set up, and I give it very high marks, just shy of perfect. Their system uses a stock pressure plate modified for additional clamping force (which others have been known to do as well), along with a unique dual material disk. When I first installed it, it had virtually no shutter. Lately I've noticed that it has more shudder when starting in first than it originally did. If I slip it a tiny bit (e.g. rev to 1200 or so) I can get a perfectly smooth engagement. They have fantastic customer service also -- no endless waiting around -- even special orders are completed in a day or two.
The good thing about sending them our parts vs. buying new is they can put a real tq test on them and have a good number vs. marketing claims, which I think Chris W. mentioned on another thread that those are not really reliable.
Also for whom ever wants to chime in:
What is the difference in ceramic vs. feramic coatings and is there any real benefit for having the PP cryo? SB quoted only $40 for the cryo so I will probably do it anyway.
About the stock PP, I am running it with Cup clutch and 350whp+ and never a slip at all. I am doing a 2.8 swap, so this is why I am looking to make sure my clutch will hold and handle it now while the motor is out and not take a chance. Plus, the reline that SB does and for a 1/3 of the cost of a Spec 3 or Kep, etc. it will still have performance.
Let me tell you why. I know this from experience because i have been told directly from the source.hence why i dont post alot of my findings unless someone comes directly to me. There prices has gone up since it was posted on rennlist. once they see the demand is high they can start raising prices specially since they are the only one that does what they do. i know this shop that does crazy welding work for a REALLY good price. i told this guy i knew and he told everyone in the honda fourms and now the guy has tripped his prices. full blown out headers from 320ss for $450 with v-bands now its $1200 plus v-band
Sounds like I need to make a dyno run at 16 psi to see how much power I'm putting down, then evaluate options to swap out some parts. The only good news is that I have a rebuild-able clutch and PP to use as cores if I need to go that route.
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
I have the Southbend on my 300ZX turbo 450 rwhp, four years no issues and love it. I would think their 951 product would be great as well. I have the SPEC on one of my 951's but have never driven the car so can't comment I have another one in a box for my CA car ready to go in, but somehow my stock clutch is still holding. My two cents worth, make sure to balance assembly before installation! Too many people fail to have this done.
