Is 2-3 bar oil pressure to low?
Old 10-04-2011, 01:09 AM
ehall
ehall's Avatar
Originally Posted by Tom M'Guinn
Also, did you undo the main crank bolt to replace belts while you were in there? It needs to be torqued properly and the pulleys need to be on right to get full pressure. 2-3 bar at idle is ok when fully warmed up, but if that's all you have when cold, that's lower than normal.
YEP!
Old 10-04-2011, 01:24 AM
ehall
ehall's Avatar
Oh that! Okay. I'm good to go.
Old 10-04-2011, 01:25 AM
ehall
ehall's Avatar
I believe the torque is 155 ft/lbs on the crank bolt.
Old 10-05-2011, 11:17 PM
slap929
slap929's Avatar
Alright.... I torqued the crank bolt down and am still have oil pressure around 2-3 bar. Any other suggestions? Its just odd because all the other problems that clarks garage points to would cause me to show no pressure or spike all the way. Thanks for the help guys.
Old 10-05-2011, 11:22 PM
ehall
ehall's Avatar
WEll, obviuously you want to eliminate all of the really important and catastrophic possibilities, but, it's entirely possible that it's the oil pressure sending switch or the guage. Make sure the wires on the switch are secured well.
Old 10-05-2011, 11:27 PM
slap929
slap929's Avatar
ok, will do, thanks ehall. I will post the results tomorrow.
Old 10-05-2011, 11:34 PM
gpr8er
gpr8er's Avatar
well this is not a happy situation. Sometimes the machinist will remove the check valve when decking the head to avoid getting debris in it. If it was not reinstalled this would explain the lifter clatter on startup. But to the low pressure problem I can't say for sure. Maybe... since it is a restriction in the oil supply to the head. I would try a different pressure sender to see if it makes a difference. Know that the wires connecting to the sender must be on the correct terminal. If not it will peg the gauge at 5 bar.
Old 10-06-2011, 12:06 AM
ehall
ehall's Avatar
True! A mis wired switch will do exactly that, but I've also seen them peg at 5 bar, if they are bad.
Old 10-06-2011, 12:07 AM
ehall
ehall's Avatar
Also, couldn't a badly leaking AOS cause a serious pressure problem. If the top of it is broken, as mine was, it gave me really low pressure. There was a ton of air leaking out of it.
Old 10-06-2011, 06:03 AM
Black51
Black51's Avatar
Does the oil dipstick read "full" when the engine is warm? Sounds dumb, but easy one to miss.
Old 10-06-2011, 09:15 AM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
that's way too low oil pressure at startup. even for 40 weight oil.
your rod bearings must be considerably worn. at the very least change to a 50 weight oil.
now that it's winter, i would consider mobil 1 5w50 'rally' or 0w50 'racing' oils as they flow very well at cold startup.
Old 10-06-2011, 11:51 AM
Tom M'Guinn
Tom M'Guinn's Avatar
Did you remove the pulleys as part of this job and, if so, are you sure you did not flip one over by mistake?
Quick Reply: Is 2-3 bar oil pressure to low?
