Will someone tell how the hell you adjust early porsche koni struts
10-05-2011, 04:50 PM
How do i Adjust early porsche koni struts with the allen key top? I have the spring off. Thank you..../.
10-05-2011, 04:55 PM
10-05-2011, 05:00 PM
I thought you had to compress the shock and it would catch then you twist. That is a rough idea but I don't know an official procedure.
10-05-2011, 05:01 PM
Front. I believe i have to compress until i get a notch and then turn a certain direction. I want to go Full stiff. Thank you.
10-05-2011, 05:02 PM
Once again these are early porsche front koni adjustables.
10-05-2011, 05:07 PM
10-05-2011, 05:10 PM
On mine (86) the front one are ajusted from the strut top (under the hood) with a special ''key'' (looks more like a bottle cap).
10-05-2011, 05:27 PM
which direction for full stiff?
10-05-2011, 05:34 PM
Can't say on top of my head, but it's not hard to try there is only 2 directions...
10-05-2011, 06:22 PM
lol only two directions... That's for the dampening of the shocks. Are you talking about adjusting the springs? I will look in the FSM and see if it says the direction.
10-05-2011, 07:29 PM
Link found on Koni web site, under the 1986 944 section.
http://www.koni-na.com/****.cfm
10-05-2011, 07:35 PM
If you have the m474 koni sport factory struts and they dont have the little tab for the adjuster key (****) you hafta remove the spring and adjust the strut like you would a rear shock(compress and turn. this is according to koni.
10-06-2011, 12:59 PM
yes, this is what i did. Thank you.
50 ,
944 ,
951 ,
adjust ,
adjusting ,
adjustment ,
adust ,
hood ,
koni ,
m474 ,
porsche ,
shocks ,
spd ,
struts ,
yellow
