Is 2-3 bar oil pressure to low?
Old 10-03-2011, 04:00 PM
slap929
slap929's Avatar
Default Is 2-3 bar oil pressure to low?
I put a new head on and started it up. The car has been smoking from what oil fell on the exhaust during the job and the the lifters are making a racket(assuming that they are refilling). My only concern at this point is the some what lower oil pressure that what it ran before the work. Was around 4-5 and as the title says, its closer to 2-3. Any clue what could be the problem?
Old 10-03-2011, 04:04 PM
carlege
carlege's Avatar
Is the head the only thing you touched?
Old 10-03-2011, 04:32 PM
slap929
slap929's Avatar
and every thing else that is in the way... I followed clarks garage and tom86951's write-ups. I am apparently missing that section in my turbo fsm.
Old 10-03-2011, 05:20 PM
Ben951S
Ben951S's Avatar
Need more info. 2-3 bar COLD? Once warmed up?
What weight oil?
thx
Old 10-03-2011, 05:37 PM
slap929
slap929's Avatar
Cold and idle, and the oil is 10-w40. Thanks for the advice/interest so far.
Old 10-03-2011, 05:49 PM
carlege
carlege's Avatar
Alot of the numbers people are getting are with 20 w50
Old 10-03-2011, 05:50 PM
Crackership
Crackership's Avatar
That seems low at cold idle, but, then again, I've never run that light of oil.
Old 10-03-2011, 06:07 PM
pnbell
pnbell's Avatar
when revved past 3k rpm does the oil pressure rise to 4-5 bars?
You are likely fine..
Old 10-03-2011, 07:09 PM
Ronin-951
Ronin-951's Avatar
10w in Atlanta? Thats a weight for 0*f. Where's Al Gore when you need him?
Old 10-03-2011, 08:59 PM
slap929
slap929's Avatar
sorry I meant 15-w40(still a little light)... been an odd day and I blame the typo on that. Thanks for the advice. I am tempted to just drive an see what the pressure will be like but dont want to damage the engine.
Old 10-04-2011, 12:09 AM
gpr8er
gpr8er's Avatar
was the check valve removed and not reinstalled? You are gonna hate life if you don't know...
Old 10-04-2011, 12:30 AM
Tom M'Guinn
Tom M'Guinn's Avatar
Also, did you undo the main crank bolt to replace belts while you were in there? It needs to be torqued properly and the pulleys need to be on right to get full pressure. 2-3 bar at idle is ok when fully warmed up, but if that's all you have when cold, that's lower than normal.
Old 10-04-2011, 01:00 AM
ehall
ehall's Avatar
Head? Check valve? Huh?
slap929
slap929's Avatar
The check valve was not messed with(dont have any reason to suspect it, but definitely not ruling it out). Tomorrow I will check the torque again, maybe this time with a different wrench, and see if its on. I will do the same with the belts/pulleys. Thanks for the help guys.
Old 10-04-2011, 01:03 AM
slap929
slap929's Avatar
I looked back at older post. Apparently there is a valve in the head that prevents oil from dropping back out of the head after the engine is turned off.
https://rennlist.com/forums/944-turb...951-heads.html
idk you tell me if this is something I should suspect. My lifters are very noisy but I just think they need some more running time to fill. Just want to make sure that I have proper oil pressure before I do that.
Quick Reply: Is 2-3 bar oil pressure to low?
