Transmission Brace
Transmission Brace
I have tried searching, but maybe I'm not using the correct terms. I'm looking for info on how you install a transmission brace. After looking at the trans and surrounding area, I can see where to attach to the trans, but not the other end. I plan to make this brace, so any help would be appreciated.
https://rennlist.com/forums/924-931-...-page-2-a.html
https://rennlist.com/forums/944-turb...ighlight=brace
I think most people have settled on this approach to limit trany movement.
https://rennlist.com/forums/944-turb...t=polyurethane
After untold hard launches and complete clutch dumps, I still haven't busted a CV...
and Toplocker Nuts that won't vibrate out......
Just drill your 85.5-up Tranny hanger to mount bolt holes 3/8"
New Mount Loaded weighs....836 grams....
I just installed one of the XSCHOP Trans mount on a 944 track car, nice quality, nice fitment
Rob is great to work with, He also has a Great Short Shift kit that I am going to install
Max
Max
I did not notice any more gear whine when I installed mine as I designed it where the shoulder bolts are completely isolated from the base-plate. With a solid mount it would definitely increase noise. I have only one left for a late trans and will build more in a few weeks. I am also building more of the short shifters I designed as well. If you haven't seen my chromoly axles, I can build them too with stronger Type 2 CV's (larger ***** and thicker cages)
Hey 95One, here's the pic....It has exactly 30% reduction in lateral and forward/aft throw.
I used the old window weld trick but also plan on adding two guy-wires on either side. This should be a very light and effective way to keep the transmission from shifting left and right.
