Carbon canister lines (weird) ?
Old 09-25-2011 | 10:25 PM
Crazy Eddie's Avatar
Crazy Eddie
Default Carbon canister lines (weird) ?
Hey Guys
I must have read 10 -15 threads on deleting these lines that go to and from the carbon canister .. BUT, me being the **** nut job that I am, wanted to keep it all stock....
I just noticed something very weird. I removed the floor board panels from the bottom of the car, and it revealed that the hose that comes from the carbon canister is terminating under the driver's seat ??
Do I have some Mafia set up in my car ?
I thought that the line was supposed to return to the fuel tank?
It seems to in PET ?
Here is a picture below
Is this normal for a 88 TS ?
Thanks in advance
Ed
So the question is ......
Does it terminate under the seat ( mid car) and not go back to the gas tank?
Old 09-27-2011 | 09:32 PM
Crazy Eddie
Anyone ?...
Old 09-27-2011 | 09:36 PM
gruhsy's Avatar
gruhsy
Hey Eddie. It goes back to the tank for sure. I replaced a section on mine.
I have some pics somewhere. I will look for them. I think I have a pic of every square in on my car
Jason
Old 09-27-2011 | 09:44 PM
Crazy Eddie
Jason
Hey Jason
Thanks bud ...
Its so weird as this is the way the car came .. I am the original owner !
So damn strange .... Yours is an 89 right ?
Thanks again bud
Regards
Ed
Old 09-27-2011 | 10:13 PM
Oddjob's Avatar
Oddjob
No - thats the vent to atmosphere after passing thru the charcoal canister. They are ususally zip tied underneath the pastic panel.
Old 09-27-2011 | 11:47 PM
samluke's Avatar
samluke
As Jim says, Yep, that's the way its supposed to be. I removed all the emmissions stuff but still retained the vent under the drivers seat and zip tied it,, to the plastic panel, just like the factory. It saves quite a bit of weight and eliminates the problems associated with the evap control.
Old 09-28-2011 | 12:11 AM
Scott H's Avatar
Scott H
Just went to check my box of evap stuff and that line is still attached to the canister and looks to be exactly that length. It makes sense, the fuel vapor should have passed through the charcoal and that should have cleaned up the "emissions," making it safe to vent to the atmosphere.
Old 09-28-2011 | 01:01 AM
Crazy Eddie
Yes that's exactly how is was .....
Thanks Jim
Thanks Richard ...
Thanks Scott for checking that out
I figured mine was still stock as I never touched it
But whats really weird is that PET has it going back to the gas tank
That would not be the first time PET was wrong !!
Thanks Guys very much
Best regards
Ed
Old 09-28-2011 | 01:09 AM
Paulyy's Avatar
Paulyy
Professional Hoon
There's floor board panels?
Old 09-28-2011 | 01:36 AM
Scott H's Avatar
Scott H
Yes. They're plastic/bakelite/fiberglass (most likely the latter given how itchy I was after drilling a hole through it...) They don't span the entire car, just the middle-ish area around where the transmission would be on any normal car. Whether it's there for aero or keeping components from dragging on the road I can't really tell you.
Old 09-28-2011 | 01:43 AM
gruhsy's Avatar
gruhsy
Ah that line yes it goes to what everyone said. Didn't have the pic on my ipad.
yes it just ties up underneath. That was what mine did. Using computer now and see it's that big line not the ones by the fuel line.
Jason
Old 09-28-2011 | 02:06 AM
Tom M'Guinn's Avatar
Tom M'Guinn
So?...what?...no one is going to mention the "ramps"....?
Old 09-28-2011 | 02:09 AM
David Floyd's Avatar
David Floyd
Fits his name "crazy" !
Old 09-28-2011 | 02:16 AM
Scott H's Avatar
Scott H
Holy crap! Did not notice that. Eddie, if that's how you did your entire rebuild consider it a blessing you're still alive...
Old 09-28-2011 | 03:04 AM
Crazy Eddie
Aahh Tom , there he goes again stirring the pot
No, its just a temp set up ....
Trust me there is no way that is moving ...
There are blocks of wood and brick and cinder block under those 4x 12 and 6x 10's
