Patrick's build thread. (IT RUNS!)
#301
That's actually pretty much what you're faced with. That is, you can go for more wheel/tyre but that might be at the expense of ride height. I was faced with the same question. I asked around a bit and got varying opinions as to what was more important, CoG or Mechanical grip? Can't say that I got 100% assurance to that question either. There are many variables to take into account. I think ultimately if you go for a bit of a compromise it may be the best way to attack it. Oddly enough when I asked a true aero expert he said against his instinct it may well suit to go for more rubber than lower ride height...but this was not taken as his outright viewpoint and he also mentioned too many variables to consider. You will be able to fit your fronts and rears pretty easily and have the advantage of being able to use spacers. I am not sure how much the B/foot nose piece adds to your space but they quote 1" either side. So this will give you enough room to play about a bit with spacers.
True enough. Add to the brakes, coil diameter, rates, bumpstops, tyre widths and O.D., Caster/Camber, track type (long fast - short tight), track surface, aero....
#303
^^Don't want to hijack Pat's thread any further. There are quite a few in-car videos links floating around in other threads. TV coverage of our series tended to focus only the leading class of GT cars, so I only have a few odd clips of the car running from the outside. One of these days I will get organised to upload a decent compilation.
#305
In case you guys think you are fast, here's Brumos Racing's Grand Am defending Champion, Leh Keen, (known as "King Leh" here on rennlist) at this years 24 hours of Daytona. I KNOW PPG won't mind, and may not have had the chance to see it. I live here in town with the team, so we get it all.
BUT THIS ONE is MUCH BETTER!
Listen for the police siren! Same drover! Leh Keen!
http://youtu.be/NnFiMaY2Dj8
#306
Let me also add this. Patrick also REALLY knows his tracks. He knows where he's going to run, mostly, and his car is set up for those tracks where he spends most of his time. YUour set up needs to be based on your knowledge of the tracks you plan to "MOSTLY" run. The end answer, to your original question is; "it depends".
Patrick deserves the, "Rennlist 951 Nut" of the year award.
This is a kind gesture. Trust me, I'm part of this merit...I just don't deserve the award.
Patrick, your car is looking f****** awesome.
George
#307
ehall, know I love Patrick, and his passion for our "particular" cars. He takes all hits, and still posts with gratitude.
George
George
It's going to take6 another minute so here's a vid to watch while I search...
http://youtu.be/Lix7ofYaxWg
#308
didn't find it yet. here's Jet's
That would be Sean's. Patrick posted it,.
#309
#310
Totally agree George! In tribute, I MAAAAyyy just have a vid of his old car on the track....gimme a minute....
#311
#312
I envy you my friend. It sure ain't all about late not car talk!
#313
#315
Pat, I can't find the one where you are starting right behind the red-ish 911. That one rocks.
I'll post one more, just for fun...like the rest weren't. and we'll get back to your build.
send me a note on facebook, if you think I stole your thread. I tried to make it about YOU! bastard!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
BTW, i think the new car will run circles around this Disimone guy!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://youtu.be/XJ82fHZB0BM
