Something I Learned Today
I was lucky enough to figure out that my car does not have rod knock before I tore it down.
I did a search to see what the fuel damper did and got mixed results. So when I replaced the original cracked rubber lines on my car I deleted the damper. The short piece of rubber hose between the damper and the rail was a little tricky to make, so I decided it was a good time to leave it off. About the same time I started hearing a slight 'tap tap tap' sound at idle. Last week I installed a Bosch 044 pump and big injectors and turned up the boost. The 'tap tap tap' got louder. I was really worried. I just happened to feel the rubber fuel feed line while the engine was running and felt a sharp pulsation in time with the sound. Then I figured it out. Since the injectors all fire at the same time they send a sharp pulse through the rail and feed line, similar to the water hammer effect
http://en.wikipedia.org/wiki/Water_hammer
So the fuel damper is going back on tomorrow.
What else should I know? There's plenty of good info on the forums, but I'm sure there's some obscure tidbits that are rarely mentioned, right?
