Something blew up
#33
I mentioned to Dave that I had setup a crankcase vacuum line with a check valve, he didn't think that would cause anything negative related to oil flow through the turbo.
#35
I've got a new Super 53 turbo on the way that will be here tomorrow. I'll try to get it installed this weekend and see how that one does without vacuum in the crankcase at idle...
#36
The thought crossed my mind, and Dave told me that I shouldn't need vacuum at idle to drain oil from the turbo - but that vacuum sure did make the smoke go away... right until the turbo blew up.
#37
53 here too...and near ZerMatt!
Cool I run a super 53 (To4E 60 Trim StageIII 8 Hot) as well. Its the one I just got rebuilt. Sounds like we will now have very similar setups. Let me know how yours turns out. I am still waiting for C-Tune to arrive. Should give you a major kick in horsepower up from the K26 you were running. Are you going to take the PCV out and try that first?
#38
#39
#42
I guess it's possible. I think the center section is ok, but the shaft is split in two. I'm not sure that I'd come out ahead after buying a shaft (I think the turbine wheel is part of the shaft) and having it rebuilt...
#43
Correct, the only two components that make the /8 worth more are the turbine (which as you correctly thought is connected to the shaft) and the hotside. You have only the hotside which has some value if people want to put a custom turbine in it or they came across an /8 turbine somewhere else and don't have the housing. A very specific market would want those parts, but as a whole turbocharger that thing is done unless someone wants to sink more money into it than its worth. It might not even be possible to source a new /8 turbine as BW has discontinued a lot of the old production lines.
#44
I can read the specs on that brown paper. Looks like the same dimensions as mine. Is this going in today? Look forward to hearing how it performs and if there is any smoke with the new turbo....Keep us posted. Good luck getting it in there. You might have to do some grinding on the turbine housing and/or small screws on the intake manifold to get it to clear the intake manifold. I just put mine back in and it was a ***** lining up the mounting bolts and crossover bolts. Finally got it to line up with long pole, rachet straps, and a floor jack. I never took the exhaust side of the crossover pipe off only undid the turbo side. It would have been easier if I could be on top of the engine and underneath the car at the same time.
