How much do these V8 conversions really cost ?
#76
#77
Rainman
Rennlist Junkie Forever
So $500 for the CNC, plus R&R... call it $1500 with a tune, maybe more with larger injectors.... 450RHWP ish
TonyG
#79
#80
The deal is that on big race tracks... (which I primarily run), you need top end power. That means power from 4000-7000rpms. Nothing below 4000rpms matters becuase you're below never that.
So a cam that makes great low & mid range won't do anything for the car on the track.
And this is the exact reason why I just swapped cams from the MTI Stealth 2 cam at 389RWHP to the Futral F-16 cam at 417RWHP (everything else besides the cam the same).
It was a direct swap of 30TQ for 30HP at the 4500rpm mark on up.
Totally worth it for a track car.
TonyG
#81
So I paid quite a bit more for things other than just horsepower in these heads.
#82
The Corvette is nice, But it doesn't have the looks of the 944![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
And, with the LS motor in the Porsche , there is not much on the road that will keep up with them especially a Corvette.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Pull up the corvette next to a converted 944 at a car show, which one is everyone going to be looking at?![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Lastly, why did it talk Gm so long to copy the drive train that we have been using for 25+ years? That's GM for you.............
#83
This leads me to believe that:
1. 2675 is your car weight without you and you weigh in at 1,065 lbs, or
2. your meant to write GTS5, which has a lower limit of 6.6.
#84
TonyG
