Since everyone else has a V8 build thread...
#34
#35
Vettes are common, 951's are not. 951s with V8s, even less so. 2200 lb widebody 500HP V8 951's... well you get the idea... or maybe you don't.
#38
I just spent ALL DAY.. From 10am to 7:30pm fabricating and measuring and fabricating and measuring. I'm beat. I finished welding metal back into the large hole I cut out on the drivers side. I welded in /blocked off the heater/vacuum hole in the firewall. I did the same for the DME harness opening. Both are now solid steel. I also spent Much of the time cutting out the cross member "notch" for the lower engine, and completely changing the position of the steering rack to a much lower spot. I also moved the passenger side rack mount out to the far side. Plenty of room for a pan to sit there now. It's near impossible to move the driver's side anywhere but lower. And lower wasn't easy in the slightest. Much welding had to happen today. with both the steel plates to fill in the hole and all the aluminum for the cross member notch and Steering rack mounts. I also used the CNC mill to drill suspension holes 1" higher and .25" further out. I can't use those holes at the moment though because the other side is still at stock height and will take a lot of fabricating to relocate those higher. Way more than just drilling another hole. I didn't take pics because I still have so much more welding to go and the car still looks a mess.
I have decided to add another Steel cross member that will be like the arms of a "K". Hence chevy's name for their LS engine mount in the trans am. "K" member. A picture will explain this way better than words, but that won't be for a couple weeks now.
#39
I seem to remember being bashed by people when I suggested using Corvette brakes instead of Porsche brakes on a track car. Good to see there are at least some people on here that can look past the name on the caliper.
#40
#41
I've been pushing extremely hard lately and all this custom "think of it, figure out how you want to do it, and then Fabricate it, Realize that didn't work and do it again" stuff takes a LOT OF TIME!!!
AND.. it was great meeting you. Not enough people stop by and say hi. Very glad you did. You gave me new ideas on wheel fitment and I very much appreciate that. There is ALWAYS something you can learn from others.
#42
Well, since my head guy is slower than Molasses. I decided to go ahead and try my hand at the Plasma cutter. Loved it. it's easy as hell and will be using it every chance I get.
I did this so that I could make the Dry sump pan. I made some example pieces out of poster board. i decided on a 3rd design. I made it so that I could bed the material with our hand brake and save a few joints / weld lines. Stronger, less chance of breaking, leaking etc. etc. I still have to weld on the flange and A/N fitting. But i wanted to show you my progress so far since I'm so damn excited how well the plasma cutter worked. Designing in the plate thickness into the design with the bends is extremely difficult. I got through it ok though. Here are the pics in succession.
Here are the plates after the plasma cut them out on the table.
After some bends were put into the plate.
Tacking it into shape, joining the two pieces.
And finally some pics of how it will sit on the stock flange I cut off the stock truck oil pan. man that flange has a lot of crazy turns. My welding will clean them up quite a bit though. I have to do some more work to the flange. I then have to tack it into key spots to keep it straight before I weld all the seams. I have to get 10AN fitting weld bungs and weld those on. it will be done after that.
#43
Rennlist Junkie Forever
TonyG
#45
Thank You!
But now that I'm looking at the pictures. I didn't do the math on the thickness of the flange. It's now 1/2" too tall and using up precious height. I guess I'll mill out the center of the flange and drop the edges of the box down to what would be the table level. Or just make another flange.. which would make me wait until I can get a 3/8" sheet of aluminum. I'll figure it out.
And for the record. The cheapest pan I could find like this was from Canton racing for $500. Ridiculous. Some of the Cast pieces are pretty nice. $600 is a bit much. Maybe something like $300. But it's whatever. I'll probably buy one next year.
