which way should i go with this engine build?
Old 05-25-2011, 08:46 PM
TheDice951
TheDice951's Avatar
Question which way should i go with this engine build?
ok, so, I have a 2.5L 8V turbo motor with about 100,000 miles on it. I would like some advice from you guys. this car is my daily driver for now and would like it to stay in that category just in case I need it for some reason later. I also want to address the lack of torque. I know the options will be limited because of the displacement. I have a GT30R on my car right now and like how it feels but I have nothing else to compare it too so that were you guys come in.
I want a reliable nice responsive engine I can drive every day and make a good amount of power out of... is 400-450 asking too much? I am planning on using rouges M-tune since I have a friend that knows him and I like the idea of it all. I was also thinking of individual coils? <<I haven’t found much on this mod<<
I would like some ideas on "hybrid" turbo setups... what are you guys running and how do they feel? this will be a slow build and most mods and all work will be done by me so money isn’t that big of an issue but not unlimited....
I am rebuilding the motor completely and will be doing some head work like porting and polishing and possibly bigger valves.
what do you guys think??
Old 05-25-2011, 08:50 PM
TheDice951
TheDice951's Avatar
to add to this.... I would like to start tracking the car... Auto-X and road racing type stuff.... we have some hill climbs back home in PA that I would like to participate in sometime.... I will be upgrading suspension here while I’m building the motor...
Old 05-25-2011, 09:03 PM
User 52121
User 52121's Avatar
400+ hp plus DD plus reliable sounds like a tall order to me
Old 05-25-2011, 09:25 PM
docwyte
docwyte's Avatar
Yeah, don't think you're going to be getting that, especially with track use. Before I put my LS1 in I talked with Chris White about rebuilding my stock motor. For track and DD use with power levels around 360rwhp he basically said I needed a built 3 liter motor, running as little boost as possible.
Something's got to give. You can't have a responsive, low lag, DD, trackable, 400-450 hp motor. Pick two, have a bunch of cash ready and you can make your goal happen.
Old 05-25-2011, 09:49 PM
ChrisJ951
ChrisJ951's Avatar
My first 944 turbo I bought had been totally rebuilt by the PO. It had a 2.5 with a vitesse stage 2, 3 inch exhaust and a lindsey racing stage 1 head and DP wastegate. I dyno'd it at 342 rwhp at 18 psi on pump fuel. That car was a rocket, but still a little sluggish off boost. 400 hp you'd need a 3 liter with some head work.
Old 05-25-2011, 10:19 PM
slap929
slap929's Avatar
Yeah so... Do you like the new GTR(r35)?
Old 05-25-2011, 10:54 PM
User 52121
User 52121's Avatar
Order up a set of heads and a nice cam from LG Motorsports. Bolt them up to a junkyard LS1. Drop that in. That should get you to your 400hp mark. Or buy an Evo and crank up the boost.
Or add a Rogue M-Tune setup, enjoy the smoothness and driveability it brings, spend the rest of your money on suspension and brakes... and then enjoy a well-balanced car on the track that can run down cars with a LOT more horsepower.
My car, power-wise, is pretty much stock (26/6 even) and I got the point-by from several GT3's at the last track day I attended.
Old 05-25-2011, 10:56 PM
schip43
schip43's Avatar
Yep, Fast isn't cheap, cheap isn't fast and cheap and fast, isn't reliable!
So... pick two. Not seen to many people saying 400+, trackable and daily driver with a 2.5. With that kind of power goal and your other requirements that would make a 3L your best bet!
So..see the first sentance above!
Old 05-25-2011, 11:17 PM
David Floyd
David Floyd's Avatar
Not going to assume your driving skill level, but if you get to 400, that will be a very fast track car, my car is way faster than I am so I tend to turn the boost down at the track to the 300 area and it is still faster than most cars in the group.
DD for 5 years, some 60 k miles during that time, now just weekend drives and track when I can, this with a 2.7 ltr
Just have fun with the build, find the best combo for power and reliability for you
Old 05-25-2011, 11:33 PM
Black51
Black51's Avatar
What is it about guys (or the cars) here not liking going over 20psi of boost? Yet, you hear guys saying "buy an Evo and crank up the boost". They're not indestructible... are they??
My point is, as long as you have the proper tune, knock count is down, and a good HG, what's the big issue after that? There are several guys here that are running far more than 20psi, on E85, yes, but still, 20psi is 20psi.
Old 05-25-2011, 11:37 PM
elargentino
elargentino's Avatar
What do you mean 20 psi is 20 psi?
Please educate me.
Old 05-25-2011, 11:38 PM
blown 944
blown 944's Avatar
I personally think you have a good turbo to use if you put a larger hotside on there (not sure what you have but just thinking out loud)
To the point of 400+ hp I think youd want to go to 3l or at least a 2.8 stroker for a dependable track car along with some other upgrades ie; exhaust, TB, IC,intake, headers and the obvious tuning solutions.
my .02
Old 05-25-2011, 11:42 PM
carlege
carlege's Avatar
You want a 400 hp reliable engine out of a 2.5 L? Sort out your Running rich problem first then handle the rest. HP does not equal driveability.
blown 944
blown 944's Avatar
20 psi is not just 20 psi fyi . There is much more to it. I have learned that first hand. I have actually logged my MAF voltage and at one point I didn't see any more voltage at 25 than I did at 17 due to too much backpressure.
Old 05-25-2011, 11:45 PM
David Floyd
As with any engine the more you get to ragged edge, reliability will go down, everything has to be perfect, you loose any safety margin the more boost you run, so you just have to decide how far your willing to go.
I for one can't drive a 20 psi E85 fuel burning beast to full potential at the track.
Quick Reply: which way should i go with this engine build?
