Rogue Tuning C-Tune MAF
#61
Drive-by provocation guy
It´s 0 281 002 421
I think it´s the largest hfm5 and i´m over what bosch have as maximum voltage from it in this pdf
http://www.guzzimental.com/documents...%20Sensors.pdf
1000kg/h at 4.33v
I´m beginning to think that i´m at the limit of my maf.
Bosch says that the tolerance above 4.33v is to big also.
But they use the same sensor in smaller housings up to 5v.
1000kg/h at 4.33v
#62
#65
#66
#67
I have the Mtune with many other mods. My car isn't called The Hulk for nothing. Joshua was fantastic and tuning was great. My biggest headache was to the venturi delete. I rid myself of as much vacuum lines as possible, less to blow a part. I run at 15-20 lbs of boost, depending on my mood. Mostly around 16lbs. I do everything to the Nenth degree, ask Joshua. Good luck and keep improving until either you die or the car does.
