Looking to buy 951.. Newbie
Hi I'm new here
and I've come across a 951 that is worthy of a purchase
I just wanted your opinions on what kind of a deal I'm getting, I also wanted some buyer's advice.(aside from getting a PPI at a porsche shop)
Here it is:
http://www.flickr.com/photos/55875676@N02/5597027834/http://www.flickr.com/photos/55875676@N02/5596444591/http://www.flickr.com/photos/55875676@N02/5597028040/http://www.flickr.com/photos/55875676@N02/5597028298/http://www.flickr.com/photos/55875676@N02/5596445539/http://www.flickr.com/photos/55875676@N02/5596445131/http://www.flickr.com/photos/55875676@N02/5596445377/http://www.flickr.com/photos/55875676@N02/5596445729/
It does have some minor front end dents.
It's a 1987 951 with 145k miles. Black on black. "sport's package"..I assume this was standard on 951s
The owner claims the engine was fully rebuilt (not just reseal of block) at 108k but has no documentation because it was done by the PO. Since then the turbo has been upgraded to a KKK (he didnt specify which) turbo running 18psi, with an aftermarket header that he said won't crack. He also mentioned that the injectors have been upgraded, and that the car is making somewhere in the neighborhood of 300whp.
He is asking 6k.
Can a stock HG hold 18psi reliably?
He mentioned that is has a stock intercooler, and radiator. He also mentioned he installed a custom piggyback "from a guy in San Luis Obispo who races 944s," That was kind of vague to me. He also mentioned it passed smog, and that the rear hatch is waterproof as well as the sunroof.
The VIN is WPOAA2952HN151724
Any advice appreciated! Thanks in advance
Here it is:
He is asking 6k.
Sounds like a seller who doesn't really know what is there..
Vin checks as a basic 944 turbo, no real desirable options (sport seats, suspension groups)..
http://www.autoatlanta.com/life/vin/...AA2952HN151724
If the car is over all clean, and passes a PPI reasonably I would say 6K is fair..
These are all cause for pause, and have a thorough PPi performed before buying, unless you feel like potentially buying someone elses problems...
The carfax report isn't reason to NOT buy it, but is reason to be concerned...
nice looking car! I just picked up an 86 for 7k...from what i read before buying a car other than the ppi find out when the timing belt/water pump was last changed...also look into the clutch if it has been changed or if it will need to be changed.
I looked for quite a while before buying..not a bad idea to check out a couple other examples out
Sounds like a money pit. Missing the front spoiler as well, I'd stay clear of this one. There are a few on here in that price range that are much cleaner. Good luck
ya i would avoid it, that mileage is probably closer to 200k plus... my title is way cleaner then that and I paid 2800 for my 951... of course I put 2500 into it for preventative maintenance lol
still worth it. Shop around, maybe look and see what rennlister may be selling. Honestly 5-6k should get you one that is in good condition, may need a little tlc, like the interior
I'd stay away from this one, unless you want a project to strip down and start over. Looks like it has been owned by someone who wanted a fancy car, but lacked the resources to care for it. Under hood is filthy, but has obviously been tampered with. Intake and intercooler pipes were painted. Looks like some aftermarket vacuum resivoir. Aftermarket wires. But again, filthy. Just looks like a typical high school aged ricer Civic type maintenance job. Option codes listed do not list an M474 suspension, but it appears to have the front shocks from it, anyway.
When you throw in the CarFax stuff which is obviously a big deal, that makes it a huge issue. If I were in the market for a track car, I'd look to spend $2500, maybe $3000 for it. Nowhere NEAR $6000.
*shrug* I dunno... assuming it passes a PPI, it seems like $6k is fair-ish. Maybe barter him down a few bucks from there?
There are definitely some red flags here... unknown mods, no documentation, turbo badge on the wrong side (why?)
Unless he can document when the belts and water pump were done, plan to do that right off the bat. It depends on the tune but 18psi is a bit higher than the average around here - most guys keep it to 15psi or less. These cars aren't Evos, they don't seem to hold up well under insane boost levels.
Otherwise it could be a driver. Realize that, with the car being 24 years old, even the most perfect example is going to take maintenance. I paid almost double this for my '86 2 years ago, all maintenance was up to date, car was really clean... and I've still easily put $6k into it over the last two years in routine maintenance. So this particular car here is probably going to need a few things. If you're stretching to afford this car, or are planning to DEPEND on this car for your ONLY transportation, you might want to look elsewhere. If you have another car to drive, and don't mind losing an occasional weekend to repair or maintain the car, then this sounds like it might not be a bad deal.
Case in point, I ran one for my Father-in law on Tuesday. It showed inconsistent mileage reports, and failed emissions tests. The seller had all records proving otherwise.
Regarding the price, I think $6k is about right for this car with all its faults and unknowns.
PPI to find things like collision repair/slash damage,records for water pump TB change and last clutch job would be important. Records and doc for what has been installed would be heplful.
Regarding boost levels my 89 S runs 18lbs of boost daily (when it runs, problems unrelated to engine
