Is this hole original?
03-14-2011, 02:57 PM
See the attached picture.
Looks almost hand-drilled?
/Dea
03-14-2011, 03:17 PM
AddictRennlist Member Rennlist Small Business Sponsor
I don't recall a hole in that location.
03-14-2011, 03:25 PM
Hand-done inspection? What can you see?
03-14-2011, 03:30 PM
Don't know, didn't get any picture fron the right angle.
Will check the coming weekend.
/Dea
03-14-2011, 05:49 PM
Quote:
Originally Posted by
Chris White
+1
03-14-2011, 06:28 PM
Chris White
Duke
+1
That's what she said!
03-14-2011, 08:42 PM
Nope not stock. Looks like maybe some sort of DIY flywheel locking system or alignment hole.
03-15-2011, 06:26 AM
Strange.... the car was completely stock when I bought it and had full documentation, all from reputable Porsche shops.
Guess I'll never know why it was put there?
/Dea
03-15-2011, 10:02 AM
Plug it. Rubber stop or a patch of some sort...?
03-15-2011, 10:03 AM
I wonder... perhaps it is a BDC #1 location hole appears to my untrained eye to be roughly 180 degrees from the TDC#1 trigger pickup?
03-15-2011, 10:04 AM
phoenix_iii
Next time the bell housing is off, weld it grind it down flush, act like it was never there!
03-15-2011, 01:12 PM
JohnKoaWood
You're assuming that I actually ever will remove the bell housing
/Dea
03-15-2011, 06:48 PM
I wouldn’t bother plugging it – most 944s do not have the lower flywheel cover so the whole bell housing is open to the road anyway.
03-15-2011, 09:36 PM
It's possible someone dropped something in there and fished it out through that hole... though I would think the inspection hole would work just as well.
03-20-2011, 11:37 AM
And finally a picture.
The BDC theory is probably correct.
/Dea
