Compression Test
Originally posted by toddk911
can you use a compressor and the same type of connector to do a leak down?
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
To a point, consistent readings between cylinders is more important than high numbers. Less than 5 psi, you're laughing. Mine's been at 135 for all four for years and it runs great. I'm sure the accuracy of cheap gauges varies widely,
Drive-by provocation guy
YOU ALL WON'T BELIEVE THIS ****!!
I was doing the test again, this time with full throttle, and the screw in part came off from the hose and it is now stuck screwed into the spark plug.
can't get a socket on it and too narrow to get pliers on it.
HELP???
HELP???
HELP???
HELP???
EDIT: I pounded 6mm 1/4" socket over the end of the fitting and then was able to unscrew it with a ratchet. See this thread.
So do you think the readings would be higher if the AFM was pinned open as well? It does sort of close like a throttle, but the volume of air behind it is so large it may not matter (unlike the throttle plate, which has less air behind it, just what's in the intake plenum.)
-Joel.
-Joel.
Thanks Steve.
What psi do you use for leak down??
Also, for the leak down do you need the guage, or can you do a rough test and just inject air, and listen for leaks??
