another stupid thread about MAFs
The ostrich is only needed if you want to tune a stock (or near stock) setup yourself.
The MAFs also play a HUGE part in driveability. While the AFMs "work", they are 20+ year old technology. They rely on a friction contact to change voltage for the DME to read. It just isn't accurate. The friction between the barn door and the housing varies. The spring tension varies. Wear to the contact surface varies. And, since the AFM is the primary sensor the DME uses to determine fuel needs, these variances can affect AFRs drastically.
A MAF is MUCH more accurate than the old AFM. So, even if you're running a stock setup, and not looking for "every last bit" of power, a MAF setup will still turn your car into a much easier car to drive day to day. It brings the "stop light to stop light" driveability of a modern car, to our 20+ year old cars.
Rogue himself clarified in the DIY thread that it's compatible with MAF, you just need to make the appropriate conversions and the "auto tune" feature won't be as exact.
Right. You CAN use the ostrich for a MAF setup....
The Ostrich will do everything the EPROM will do, because that's what it is... an EPROM emulator. The key to this is, you need someone to give you their tune to use in your ostrich. Good luck with that!
Ok! I agree with you about the accuracy of the MAF and all its advantages.
After all, we have been providing the TRUE MAF conversion for the 944/951 for many years now.
However if his AFM is functioning properly AND he is not "after last bit" of spool-up, performance or drivability, then the AFM will serve him fine. (Under these conditions he does not "need" a MAF for the K26).
Right. You CAN use the ostrich for a MAF setup.... Give Vitesse a call, and ask him to send you the MAF code he uses, so you can use it with your Ostrch.
In my opinion.
Hmm I'm pretty sure he is not using the high impedance injectors to get around the batch fire issue. I am using siemens 95# injectors and my car idles perfectly, is very smooth throughout all rpms, utilizes 3d mapping including a lean burn cruise map, has overboost protection, etc....
Matter of fact I know the MAF's have been measured so the transfer function is dead on. I have used two completely different MAF's (cobra and lightning) without a piggyback at all and have perfect afrs.
I also know that it has been a lengthy process to get this far and it was done from the ground up re writing the code without sourcing any other vendors products.
I am very sure everyone will be very happy with the end product and price.
I'm surprised with all the open source tuning I see on here that no one has tried using a Ford aftermarket MAF /w housing. I've seen these sensors go for 50-75 dollars before and then add in the cost of the housing and then tune in the MAF curve into the ECU. I've seen these handle goofy positions before without screwing up the readings and can handle way above 500rwhp (housing is a factor).
Small Business Partner
The stock batch software requires injectors duty cycle so low that the injectors are no longer controllable. Well the Vitesse software takes care of it. While some opt to run the much slower reacting hi impedance injectors to get around this problem, we rewrote the software to handle it the correct way and to keep using the correct type of injectors which match the injectors driver in the DME.
In fact, without the proper code changes, the high impedance injectors are nearly impossible to tune and will result in uncontrollable AFRs at low loads / idle.
As you mentioned, the proper way to handle large injectors is by changing the injection strategy from firing the injectors once every revolution, to once every two revolutions.
Re: AFMs, I've tested quite a few AFMs on my flowbench... The amount of variance is scary. I've attached an overlay of eight 951 AFMs; all came from running vehicles. Though it is harder to see at the lower airflows (due to graph scaling), on average the meters measured anywhere from 10%-30% different from each other! It amazes me that AFM cars run as well as they do, but as our AFMs get older and used more, they will only continue to lose accuracy - resulting in both improper AFR and timing.
Furthermore, the AFM is a definite restriction. With a proper MAF, I would expect a 951 to make at least ~5% more peak hp, and certainly even more under the curve.
TT @ Vitesse was the first, and until recently, the only to properly change the code. The Vitesse software / kit is top-notch, and set the bar very high - without a doubt has been the best option for anyone wanting to keep the stock DME.
It was this level of caliber that I've been working towards, and has taken a long time... But I'm just about ready - when I am I'll be sure to make an announcement.
No one can get you 100% on target tuning wise to match your car remotely. There is no way to tell how your boost curve looks like. You can hit 15psi at 3000rpm or 4500rpm! So we program the software to error on the rich and boost friendly side when you go to Wide Open Throttle. In case you have a laggy turbo and your turbo doesn't wake up till 4000rpm, you do not want to be running "boost friendly AFRs" when your car is not making boost. Also if you have a ultra fast spooling turbo, you may need to richen or lean the AFRs accordingly.
Hope I answered your questions regarding the Vitesse MAF.
I am a little puzzled by this particular paragraph? Why would there be a problem utilizing different spooling turbos and the tune to go along with them? As I understand it the maf is reading airflow which is targeting a particular cell for the IDC and the map is reading pressure which is targeting cells in the timing map. Along with the tps you should be able to target the proper fueling and timing regardless of the turbo? This is an honest question..
