Should I Upgrade My Stock Injectors???
I am looking to get some advice on the mods that I am planning to my 87 951. The car already has a LR DP Wastegate, 3.0 FPR, LR MBC, a catless stock exhaust system, and MaxHP chips. I am planning on installing a catless 3" exhaust system and a LR QuadMAf this spring. My question is should I also upgrade the ingectors to #55 or are the stock injectors fine with this setup? Or is this something that I would only need if I upgraded the turbo as well? Thanks in advance for any recommendations.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Rainman
new injectors have the benefit of being well, new (and not 24 years old), and being a larger flow-rate means they dont have to work as hard as your stock ones do to provide fuel for your current power level. that said, if the stock ones are supporting your mods the 55's would provide some nice headroom in case you wanted to add some more go-fast shiny bits.
Thanks for the quick response. I am looking to run around 15 psi of boost max. Not sure of a HP target - 260 to 280 maybe? Would the #55 injectors provide more power with my setup or are they overkill?
The injectors themselves won't "provide more power." They will give you the ability to add more fuel when you decide to run higher than stock boost levels, and by having a higher flow rate, you won't run the risk of hitting the max duty of them and potentially running dangerously lean. As Spencer said above, it gives you more to work with in the event you decide to upgrade further down the road.
I would say you need to upgrade the injectors anytime you're going for more power, just size them correctly for your end goal and have the proper tuning. The stockers will nearly max themselves out after a handful of mods. With your planned mods I would go to atleast 55#, maybe a bit more if you are planning more mods down the road and you want to future-proof.
55# injectors will handle 95% of anything you'll ever want to do to your car. The only reason I chose 80# injectors is because there is nothing between 60# and 80#. I'm planning ~20lbs on a 2.8.... and occasionally E85 on track days. 60# would have run my engine/boost levels, if I didn't want to run E85....It would have been near their capacity, but they could do it.
Talk to Russel Berry, John Vitesse, Dave Lindsey, Chris White, Dave Mcgrath, Vic Power, or any of the tuning houses about parts selection vs goals.
They will be able to best advise you in selection of bits and pieces to make it reliable, usable, safe and most importantly fun!
Be advised.. speed costs money, how fast can you afford to go?
