Should I Upgrade My Stock Injectors???
My 89 Turbo S has the same mods as yours and my Max chip was burned for the 55's. The PO ran it at 18 lbs on 91 octane with out problems. I backed it down to 17 although it did hit 22 at sea level,forgot to readjust for sea level but without incident.
Sooo i'd say yes at least 55lbs but I think you'll need to get the chips reburned for the 55's and the MAF if that was on your list.
I really don't know what I should, or can talk about, simply because Rogue hasn't officially released anything yet.
I will say that I am using the 80# injectors with the stock DME, and tuning is not an issue at all. Infact, my car runs MUCH smoother, at idle and part throttle, with the bigger injectors than it ever did with my stock NA injectors.
I'll let rogue chime on why he chose this route and I'm not sure what the supplier is, but I will say his car is probably the smoothest idling/accelerating 944 I've been in.
The fuel metering algorithm in your DME is programmed based on a specified injector flow rate (along with a specified fuel rail pressure). Replacing old injectors with new injectors is one thing, but you can't simply "upgrade" to higher flow rated injectors for more performance. If your current setup can't handle a certain amount of boost or air flow, you need new chips (and complimentary injectors, whatever those turn out to be), not just bigger injectors period.
Impedance
Injector impedance describes the electrical resistance of the solenoid windings. These are usually grouped in two categories:
Low- 1.7 to 3.0 ohms
High- 10 to 16 ohms
There are some exceptions to this, notably the Bosch 803 injector used on the Porsche 944 turbo which is 4.7 ohms. Most manufacturers have used both types at one time or another. The trend lately is to use high impedance types in most production cars. The best way to determine impedance is to put a digital ohmmeter across the two electrical connections and see what it reads. The primary advantage of low impedance injectors is a shorter triggering time. When large injectors are fitted to high output engines, low impedance injectors will often give a better idle quality because of this fact. The primary advantage of high impedance injectors is the fact that less heat is generated in the drive circuit and often no external resistors are used.
I am looking to get some advice on the mods that I am planning to my 87 951. The car already has a LR DP Wastegate, 3.0 FPR, LR MBC, a catless stock exhaust system, and MaxHP chips. I am planning on installing a catless 3" exhaust system and a LR QuadMAf this spring. My question is should I also upgrade the ingectors to #55 or are the stock injectors fine with this setup? Or is this something that I would only need if I upgraded the turbo as well? Thanks in advance for any recommendations.![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Injectors are cheap. Once you mod your car to produce over 300whp, you should update your injectors. Whatever software you use will be designed for a particular injector size, impedance, and turbo.
