What is everyone's project for 2011?
#136
Small Business Partner
#137
Sounds good you guys. Nice to hear Sid all up and excited again. :-)
#140
For the 951:
-Install S4 Calipers, new rotors all around, Pagid Blks, Paragon cooling scoops
-belts/rollers/wp
-sway supports, delrin bushings, adj. drop links for CS sways
-oil cooler seals...or go with something like the Lindsey cooler
-roll bar
-Recaro PP's or GT3 (can't decide on this one)
968:
-belts/wp/rollers, cam tensioner pads
-KW's and ER bushings
-CS sways
-CS arm rest, cubby, door panels, crank windows
-CS steering wheel
-euro turn signals
-glove box supports
-rocker panel gaskets
and I need to get a '74 Alfa painted by Father's Day....ugggggh
-belts/rollers/wp
-roll bar
968:
-CS sways
-CS steering wheel
-euro turn signals
-glove box supports
#143
Here is as many things I can think of.
Finish custom wheel wells. Flat panel off bottom of car.
Build Custom Aluminum Torque Tube.
Finish Front custom tube frame for car.
Complete Bolt able cross bracing for front.
Smooth out and flush in All fiberglass body work
Install fiber roof panel.
Have everything painted
Engine.. Completely rebuild with custom pistons and rods.
Re-make another Turbo system.
Re-do Motec wiring to include a second injector set
make super baller intake manifold. ITB/Aluminum/carbon fiber/overhead injectors
Install custom wiring kit for everything.
instal all safety Gear.
make complete Tilton set up work with new lines and fittings.
get 911 turbo brakes to fit inside wheels. (re-make brackets for 17" wheels and smaller rotors.)
Tune motor.
Set up IQ3 Dash and sensors.
Drive car for short sessions while finding out what I missed.
Add about a thousand little things in between.
Tune motor.
#144
That's a **** list there Bruce!!
Like to see the wheel wells. Are you doing these to run BIG rubber?
What do you mean X bracing for front? Where on the front?
For the roof panel, are you talking in place of the sunroof, or the whole panel?
Just looking at the wiring thing myself. It's a bit daunting.
Doing Tilton pedal box...floor mounted. Moving seat back and lower to work position better + lower CoG.
You doing floor mount? Seems a bit easier dimension wise.
#145
X-bracing up top..front of cage to top of struts.
Full roof panel. not just sunroof.
Tilton overhung. It's tougher to place correctly, but I already have much of that done.
