cost for parts, engine re-build for changing my 968...
Old 05-30-2010, 12:50 PM
  #31
V2Rocket
Rainman
V2Rocket's Avatar
if you decide to change engines to LS# or 951 i might buy your '68 motor.
Old 05-30-2010, 05:14 PM
  #32
95ONE
95ONE's Avatar
Originally Posted by odurandina
are there any successful 3.0s turbos that have been built from variocam blocks without doing much more than changing to the stout rods,
and new rod bearings on the existing crank ??...
yes, they all (That i know of) pushed them beyond 400hp though and killed them in short order. AND no/yes.. Weston Dillard has been beating down a completely stock 3.0 bottom end with an 8v head for years. keeps power right around 350 @ wheels.
Am i going to do it with mine? Hell NO. Pistons / Rods are getting upgraded. Stock 968 variocam head. custom everything else..
Old 05-30-2010, 07:11 PM
  #33
CPR
CPR's Avatar
on that $35 k engine, what caused the failure ?
Head gasket.
Originally Posted by Tedro951
When I read this thread I get a "CVRIV" feeling....
Abso-frickin-lutely.
Old 05-30-2010, 07:13 PM
  #34
ehall
ehall's Avatar
Few will ever be THAT bad! lol
Old 05-30-2010, 10:55 PM
  #35
V2Rocket
Rainman
V2Rocket's Avatar
you can put 951 rods in a 968 engine, no?
Old 05-30-2010, 11:03 PM
  #36
PorscheDude1
On the Radar
PorscheDude1's Avatar
Don't think the 951 pistons fit the the 968 block without motorsport piston shims.....
Old 05-30-2010, 11:18 PM
  #37
67King
67King's Avatar
what are the respective rod lengths? With such a drastic stroke difference, rod length is usually changed.
different bore sizes mean different pistons. Are piston shims found with blinker fluid and muffler bearings?
Old 05-30-2010, 11:23 PM
  #38
gt37vgt
gt37vgt's Avatar
show the quote where it suggested 951 pistons in a 3.0 ??
the rods are the same length the pistons are different pin heights
Old 05-31-2010, 08:56 AM
  #39
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
2mm of duct tape on each side will do the trick.
Old 05-31-2010, 09:07 AM
  #40
Chris White
Rennlist Small
Business Sponsor
OK – I’ll break it down a tad –
There are five distinct steps to building a good one off motor like a 16v turbo –
You need to know what configuration works (crank, rods, pistons, manifolds, turbos, wastegates….)
You need to know which aftermarket parts work well (you will need a lot of non Porsche parts, you need experience with the vendors to know what actually works and lists)
You need some decent machining abilities or a connection to a good machining shop
You need good engine building skills and tools (plastigage is not a ‘good’ building tool!)
You need the ability and knowledge to tune it
You can be an engineering genius but if you miss one of those steps your project will most likely fail like many have in the past. Finding all of those in one place is not easy….
BTW – ‘wormholes’ 16v turbo really sounded nice at Watkins Glen on Friday/Saturday – he was voted ‘best prepared’ by the corner workers!
Old 06-01-2010, 03:21 AM
  #41
95ONE
95ONE's Avatar
weird.. one of my posts are missing?
Rod lengths are the same, just make sure the crank end of the aftermarket rod clears the block. .. Pin heights are changed.. Not good for a turbo motor.. Leaves less meat, for the top ring land, and less design room for the top part of the piston, but not crippling in this case. The Piston is also larger for the 3.0. You will need to modify the 16V exhaust to to mate up to the turbo. The Stock intake takes up too much space where the turbo will go, so you will have to make/buy one.
Putting it all together. (bottom end only) Well, I'll just say that I have someone else I trust to do that. - I need someone else to bitch at for something!
Old 06-01-2010, 03:43 AM
  #42
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
968 Turbo S pistons ?? a mint (woefully $$$$) ????
it seems from what i'm learning... (137 seconds before Krazy Karl's motor started losing power) and i barely know what i'm talking about, that there comes that moment when the engine should be pulled and the crank turned and bearings replaced, do a valve job and maybe some other stuff. but i'm wondering...
can partial rebuilds bear any fruit ?
what i'm saying is; if 2/3 of the wear is on the rings, why not just turn the crank install the new size bearings, oil pump, do a valve job, and new cams, belts, rollers etc right there, and put a set of oem sized rings right back in there ? or rings just slightly over ?
or if you go this far, you're stupid not to send the block out to be done too ?
Old 06-01-2010, 04:05 AM
  #43
gt37vgt
gt37vgt's Avatar
i don't understand the $1500 for new cams for what started as a modest build ..
Old 06-01-2010, 08:04 AM
  #44
Chris White
Rennlist Small
Business Sponsor
Don’t get your crank turned unless it is damaged.
The journals are heat treated at the factory and they are very hard, usually they are in great shape and a quick polish is all they need to be put back in to service.
Old 06-01-2010, 07:36 PM
  #45
ehall
ehall's Avatar
I'll try to answer your one question. Based on your goals, I don't think a partial rebuild would bear much fruit.
Quick Reply: cost for parts, engine re-build for changing my 968...
