Finally finished cleaning the engine bay
#92
braided lines
I am going to put something to protect the lines, but have not decided the routing just yet. Thanks for the heads up on that I will add it to my list.
#93
Rad stuff.
Hi Chris how are you?
Thanks for the info on the oil line. I will make the change today. I do have the larger pulley though so if I run into any issues I will let you know.
I used 2 different rad lines the silicone blue which was too large diameter because of the big pulley. In the end 944 106 237 05 is the hose that fits with 1 inch trimmed off.
Thanks for the advice on the Evans. I will be extra careful when pouring. I'll probably bring some pig blankets from work so if anything spills it won't touch the car
Thanks again
Thanks again
A couple of notes –
The lower radiator hose needs to be trimmed shorter by about 1” to make up for the extra thickness of the radiator – it will sit better that way.
The oil line is supposed to go on the outside of the lower radiator hose – that way it will not kink.
When you add the Evans coolant make sure you don’t spill or leak any on the engine – the free air boiling point is so high that it will never boil or evaporate – and you will smell hot coolant forever!
Looks pretty nice!
Looks pretty nice!
#94
#95
Hp numbers
Someone with a similar build to me had 458 hp according to the post on RL. I have a few more things done to mine compared that particular 3.0L build though.
I hope to run between 425 and 450 using moderate boost but we will see what tuning does.
#100
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
He is from Canada - to them a heat wave is 20 degrees...
You really don't 'need' two fans to cool the system with a larger radiator. In fact once you are over 25mph you don't need any fans. Most of the cooling problems that 944s face are due to 20+ year old radiators.
If you live way down south the second fan does come in handy in the summer when stuck in traffic!
#101
#102
Ha
#104
Started my Car for the first time last night. Lots going on so it took me longer than I hoped to get it back together. Broke in the solid lifter for 30 minutes. Ran well.
Exhaust sounds great and I'm using a Kevlar timing belt
