Introducing SeaFoam into a 951 engine?
Defending the Border
Rest In Peace
Rest In Peace
Pretty sure it should be upstream of the turbo, is this true?
Any suggestions?
I'm looking to eliminate any carbon problems before attempting smog... again.
Thx
Any suggestions?
Thx
It needs to be downstream of the throttle body - otherwise you won't pull enough vacuum to suck it in.. The typical place people do it is at the brake booster port. I would do it on the vacuum port that it in between cylinders 2 and 3 to give you the best chance. Actually, come to think of it, you might introduce some in all of the ports, since there are ports between all three pairs of runners.
Reminds me. I need to do my Mazda again. Direct injection engines have one very big drawback.
Rest In Peace
Rest In Peace
Having said that, I'd do what the other guys said, first. Good fuel additive, and give it the Italian tuneup. The only reason I've done Seafoam is because the car I use it on is direct injection.
Rest In Peace
Rest In Peace
The car has had several drives out to Vegas in the past two months, and I doo get my foot into it.
and I regularly use gas additive so I don't think there is much carbon. Just ruling out any chance of not passing this time.
Yep.. I do a scoot up my "test track" and back and leave the engine running for the test. Funny thing is, I set FQS to #4 to pull almost 3deg and the NOX in the 15mph shot up -- weird.
Strange, when I pulled the #4 fqs, it helped me out, bigtime. How's your cat? With my 3" exhaust, I bought a universal gigantic cat and that's what ended up getting me through. Took it off right after...;-)
Oh, does your guy let you do test runs before submitting? Might be something to think about before taking the risk of failing twice in the state's system... Gotta love Cali..
Rest In Peace
Rest In Peace
The old cat (missing the front element and slightly clogged rear element) pulled 1755/1585. Nearly double CA max.
It's funny Orileys ad just arrived.. Techron is $8 and SeaFoam is three for two.
Just be careful with the seafoam, it smokes a lot, thicker the smoke - more particles in it - Turbocharger. I like seafoam on non turbo applications, especially marine applications, which is where is was designed for; most marine engines run much cooler than car engines. good luck, feel for you guys in CA.
Rest In Peace
Rest In Peace
Maybe the turbo hot section could use a good cleaning too..
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Would a slight vac leak have an impact on NOX.. I did notice a slight oily sheen around that brake booster line tee.
Bannana Shine
Install water/methanol injection, enjoy the lower charge temperatures for denser charge air OR use the effective octane increase to run higher boost without knocking...and as a bonus, the more time you run the engine on boost, the more deposits you clean out! ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
See...you have to make your car faster...FOR THE ENVIRONMENT!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
chris 944CS when are you going to send my book or the $40
