Some Pictures and Update
Hi Guys,
Thought I'd give an update on the progress of my car. We are at the final stages, and I thought some of you might like to see how we mounted the front oil coolers, and some pictures of this newly designed vertical intercooler.
One of the oil coolers has a fan that will run via thermostat. The other oil cooler will be static. The mounting locations provide good air flow.
We also installed a thermostat controlled fan driven trans cooler and installed D9's hood vents. We will be using D9's dual lens fixed lights.....SEND THEM TO ME!!!!!!!
One of the consistent issues I was having with this build, was just too much damn heat. Not overheating, but not having sufficient shielding around the headers and turbo. This created some issues, and the downpipe was melting my pan gasket. We put custom shielding everywhere, and decided to add additional fan driven oil and transmission coolers. Heat kills transmissions, and I'm asking a bit from mine. Overkill, maybe, but we did it anyway. I'm also running Evans coolant, which will help keep things cooler in the head. We installed a steam vent, even though Evans coolant doesn't steam. I think it's a good idea anywway to have a consistent way to get any air out without opening the 10mm bolt.
If you look closely at the first picture you will see the factory air intake hole and the 4" intake pipe. We are fabricating a 4" cold air intake that will extend into this factory location. The filter will reside is a housing in the fender forward. No more under hood filter, therefore much cooler intake air. The front wheel will have to be removed to service the filter, but I wanted things as cool as possible.
Also, notice how much room we have now that the pop up lighting assembly is removed. It allowed the fabrication for the intake to be much easier and stay at 4".
Enjoy the pictures.......We are almost done!!!!
George
George
His calculations were based on the flow of this turbo, and my consistent power goals. He does not sell intercooler kits. He builds these one off for each car and it's intended use.
You can't see the design of the bottom tank at the intake, and this is how the intercooler was designed. Flow from top or bottom shouldn't matter. There will be a bit of pressure flowing through the intercooler. Know this intercooler was designed by an engineer that builds some crazy, but reliable Porsches. He actually used to teach the engine building classes for PCA.
Sorry if I'm sounding like a smart-***. Whether the boosted air enters from the top or bottom is irrevelant, as far as considering potential heat rise and the ability of this intercooler application to work as designed.
Thanks for the post.
Yes I know that it's "sort of the middle, but the point remains. The air flows, so it doesn't have time to stagnate and rise.
Looking very interesting George. Look forward to seeing how the air filter location turns out? Clearly you will need the new lights for this.
