Turbo upgrade for 250 BHP 951
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Hi all,
just want to hear your suggestions and not least experiences with upgrading the KKK26/8 turbo.
I am searching a wide powerband and 340 BHP maximum and have already bought Lindsey Quad MAF kit, adj. fuel pressure, LR dual port wastegate & boost enhancer. I will in very near future buy chipset, 3" downpipe and 3" Exhaust Mufflex.
With these rather modest changes what will you expect to be best turbo wise? Stay with 26/8, upgrade to K27/6 or/8, go to Garrett or something completely different?
I would rally value both advice but mostly on-hand experience from people who have been there and done that
Happy Easter every one!
Niels
Niels
Small Business Partner
Best performance for the price is going to be a K27/6 or K27/8.
All out best turbo for that hp would probably be a GT2871R.
-Rogue
-Rogue
Keep the k26/8 and get a new compressor and a new turbine put in it. Design has changed a lot since this turbo was built and turbines and compressors that fit in the same place will do a lot more.
It isn't the housing that matter most - it is the CHRA and wheel design... the KKK stuff is ancient in comparison to the new tech wheels. Sid runs a larger turbo in his car then I do, but his spool and transient is still better then mine - simply due to the fact of better design CHRA and wheels.
the middle bit and the spinny bits i would think you could send your turbo in and have one of these put in i would think for 1200 or less
http://www.atpturbo.com/mm5/merchant...gory_Code=CHRA
Niels, since you are living quite close, i suggest you to have your original turbo modfied instead of buying something from outside europe. Conatct me with PM, so i can tell what we have had done for our KKK's here in Finland.
btw do you hang around the danish 944 forum ?
any i would say with some support from others do heaps of other stuff to the car first .
exhaust injectors waste gate as you may well get what you want from the k26/8
It would probably be a good idea to get the bearing assembly replaced and run the stock turbo with the stock components until you learn how to drive it.
With a boost controller, the k26/8 will do enough air to make more than 340 bhp. I ran my stock 26/8 turbo at the track successfully for 3 years.....they're made of good stuff.
