Brake booster shield delete pictures
Anyone have photos of how they attached thermotec blankets when they deleted the brake booster heat shield?
I'm thinking I can wire it up around the booster at the back and attach to various things up front but would like to see some photos of successful installations.
I currently don't have the steering u joint shield (fell off long ago) if that makes any difference.
Also, the bracket for the turbo water pump seems a bit flexy without the brake shield there for it to attach to. Has that been a problem for anyone?
Rennlist Junkie Forever
That will keep all the heat from the booster.
TonyG
I'm going to use your trick of folding over and stapling the edge for a good clean look. When you say upside down "U" shape on the pipes, does that mean leave a small gap?
Eventually the downpipe and crossover will also be thermally coated.
I have the header blanket material and was planning to do that. If that will be enough that's great
I did this a while back and found the blanket wouldn't hold up to the heat on my car. The foil became brittle and cracked/flaked off after only a few drives. This was with a single layer just to see what would happen. If I was doing it a again I would try at least 2 or 3 layers. I also folded the edge, but used stainless steel wire to secure the edge by weaving it through the folded edge. I left some extra wire on both ends and twisted them together to secure it once on the turbine housing.
http://www.summitracing.com/parts/THE-14004/?rtype=10
Anyone else have similar problems with that material?
I've used it to shield the the turbine hot side all the way back 18" in an upside U shape to cover both the pipes entering the turbine for years and have never ever had it come apart. In fact I've even R&R'ed the turbo and reused the same piece with zero issues.
Did you support it with wire so it doesn't flop around due to the air turbulence under the hood?
TonyG
I guess it would depend on how you use it.
TonyG
TonyG
You guys who have had problems with your header wrap not holding up, I'm guessing you didn't spray it with hi-temp silicone coating? This is an important step, if you want it to last. It also helps prevent the wrap from absorbing oil/gas or other combustibles.
As far as the turbine housing goes, I'm running a full Garrett turbo with a T3 turbine housing, and I've got a DEI T3 Turbo Shield. I'm pretty sure it would fit just fine with a KKK housing.
My header wrap help up fine, but I used that spray on the headers and the wrap. I pulled it all off due to an oil leak though and going with the foil covered header blanket to avoid soaking up future oil spills. I'm lucky I didn't have a fire, but then the car hasnt been running much for awhile ha!
Those turbo shields are nice but a bit too pricey for me right now.
TonyG
Here's a photo of my custom 3" downpipe with header wrap, prior to spraying the silicone coating.
Here's a photo of the same downpipe after spraying with the DEI coating. The wrap becomes hard when it dries. Also shown is the DEI T3 turbo shield. The guy at Lordco (a Canadian auto parts store) was shocked at how much the shield costs, so he fudged the numbers and sold it to me at just over cost ($165CAD).
