How many lbs of boost do you run on the street?
Old 02-24-2010, 01:46 PM
  #31
JohnKoaWood
JohnKoaWood's Avatar
I run 16lbs, tuned, wideband, bunch of other crap I have thrown together... wicked blowby on #3 and a turbo that like spitting oil after 15PSI.. not to mention the sprinkler seal that activates over 15PSI...
I will be lowering it to avoid oil spitting and knock, GD I need a different setup, cause this p**sy 26-6 just don't cut it anymore, I NEED MORE BOOST...
Old 02-24-2010, 01:50 PM
  #32
choinga
choinga's Avatar
I'm dialed in at 15PSI on 93 gas in 3rd gear. If I floor it in 4th it will hit 16PSI.
I have a Vitesse MAF, Tial 38mm, 3BAR and 83#'rs and the SFR 3" with no cat.
Old 02-24-2010, 03:15 PM
  #33
ilikemy944
Going with the pack
is quite monotonous.
ilikemy944's Avatar
Maybe I was being a bit scary but on the k26/8 car I had with Vitesse MAF, 72lb injectors, full exhaust/tial/etc. I was running 22psi every day. _Lots_ of fun.
Now I run 15psi or whatever the Autothority banjo bolt did to my stock 86.
Old 02-24-2010, 03:35 PM
  #34
docwyte
docwyte's Avatar
I'm going to run 16psi with Vitesse stage 2 at altitude 91 octane and 18psi with race gas, overboost protection set at 20psi
Old 02-24-2010, 04:11 PM
  #35
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
Vitesse is the **** isn't it.
Old 02-24-2010, 04:31 PM
  #36
JohnKoaWood
John,
How is your new car coming?
Did you ever end up picking up what you wanted?
  #37
Darwantae951
Darwantae951's Avatar
16lbs on 93 with MBC and SciVision MAF.
Old 02-24-2010, 04:35 PM
  #38
blown 944
blown 944's Avatar
25 daily on e85
30+ when I'm feeling froggy
all with hommade stuff .. with the exception of Rogue's tune
Old 02-24-2010, 05:58 PM
  #39
toddk911
Drive-by provocation guy
toddk911's Avatar
Originally Posted by blown 944
25 daily on e85
You don't have to rub it in!!! lol
I would do anything for E85 local.
Hopefully in the near future Rogue will work some magic on a chip for me.
Old 02-24-2010, 06:12 PM
  #40
Adonay
Adonay's Avatar
I am running 13Psi at the moment Vitesse stage 3 will use more like 20+ on E85 next summer
Old 02-24-2010, 06:38 PM
  #41
Mike1982
Mike1982's Avatar
With my mods now I run about 16-17 on the street but turn down to 14 at the track.
Old 02-24-2010, 06:42 PM
  #42
Cory9584
Cory9584's Avatar
I run about 20 psi
Old 02-24-2010, 09:19 PM
  #43
buxton
buxton's Avatar
16 psi with Russell's chips burned for 15 to 18 psi on 93 octane with a 26/8. Stock injectors, MBC, Tial 38 & 3 bar FPR. Be sure you get a good boost guage and don't rely on the stock guage.
Old 02-24-2010, 11:58 PM
  #44
944Willie
944Willie's Avatar
Default chip opinions
Thanks for the responce. What do you think of Russell's chips? I have the same (I think). Did you notice any difference from your prior and now comparison? It was reccomended to not install the chips until I had installed the 3 bar FPR and the bigger exhaust. Did you get the same directions?
Old 02-25-2010, 01:10 AM
  #45
porshhhh951
Originally Posted by JohnKoaWood
John,
I've had a hard time to say the least. I believe I finally have what I want worked out now. Its been snowing for 2 days straight around here and will be snowing all week. To say I haven't been making it a priority is fair.
Depending on market it looks like used GS or used zo6.
Quick Reply: How many lbs of boost do you run on the street?
