KW V3 ride height recommendations
Yes, GO951 is pretty sick at the moment. We will be transplanting all the hardware across to GO952 in the next few weeks.
https://rennlist.com/forums/944-turb...44-pics-3.html
Definitely painful at the time, but what makes it worse is seeing the car everyday at work.
GO952 is a Black 86 but not as good an example. Still, it will be mostly a track car so
not to worry. GO951 may rise from the ashes yet.......
Going to install the same coilovers when I get back to NY, hopefully soon. All this rideheight talk makes me just want to bring it in and have it done..
. Is it tough to dial out that 'preload' between the torsion bars and coil springs? That is my big concern.
I'm going to drop the entire rear suspension anyhow.. Need to replace my torque tube 'while I'm in there'.
As an aside, I'd be interested to hear from all the people who have fitted the KWs and see what they have had before and how they compare. Have your friends been in or driven your car and what sort of reaction do you get? Just interested is all....
Lowered the rear so that it is about 350 at rear/335 at front. Feels good! Taking advantage of a bit of rain this evening, I took it out to a spot where the rear will usually break away with even a hint of rain. No break away! So an apparent improvement with respect to a bit of inherent oversteer in my previous set-up.
Actually, I'm impressed with how much of a difference the KWs in the rear makes -- if anything, the difference is more even noticable than the difference from replacing the front struts. I really didn't expect that.
This is shaping up to be a very promising upgrade over my previous set-up. Early days yet, but so far, so good...![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Well, I've still got about 15mm of adjustment available down in the rears, so it will be easy to try a flat set-up at 335mm (or so) all around to compare.
Still, makes you wonder what the KW engineers were thinking... maybe there's something in their set-up design that favours the recommended 20mm difference? Which brings us back to my original question, then.
Oh well, a bit of trial and error will sort things before any sort of theoretical conclusion will be reached, I guess.
Are thinking of getting a corner balance balance done anytime soon, Eric? Who do you think you would use (or were you thinking of getting some scales and DIY?)
I've been debating doing this myself so I can adjust my KWs easier. What weight springs are you using in the rear? And did you order them direct from KW or someone else?
Also, have you modified the control arms at all? I'm at about 315mm front (317mm rear) and my arms have definitely lost some travel. Debating installing the Racer's Edge arms. Or maybe I'll just delete the torsion bar and raise the car up a bit again.
If you decide you want to change the base rideheight settings, then the options are springplate eccentrics (as assumed by the KW installation manual), reindexing or deletion.
Once you've reindexed the first time, there doesn't seem to be any advantage to deletion over reindexing (at least that I can see). Perhaps if you change spring rate drastically at the rear you may want to reindex -- I don't know. The advantage to reindexing over deletion (for me) is that a) less stress on other mounting points (a long debated issue over whether this is a real problem, of course), and b) that's the way KW designed their kit for these cars.
The latter is the clincher for me, at least to get started with the installation. I like to know how things are "supposed" to be before changing things to how I think they should be.
The final consideration is that if I leave the t-bars alone, if I need to send one or both of the rear shocks off for a warranty repair or service, then I can just sock my Bilsteins back in and keep driving. At this stage, it appears KW doesn't provide replacements while your shocks are being sent back to Germany for repair --- could be a long wait.
For me, reindexing/deletion would get me 15mm of extra adjustment of height lower -- not sure whether it's worth it at this stage.
Anyway, as I said, first things first. Good luck! So far, I'm really enjoying these. I'm taking the car out for a run on the track tomorrow morning, I suspect I'll have a bit more to think about after that.
