Innovate LM-2
Innovate LM-2
Its taken everything I have to avoid the mod bug. Russells chips, 3bar, cat bypass are installed, and a wastegate in a few months are all I PLAN on doing for power, so help me God.
With those changes alone, I'm curious about what my AFRs will do. The LM-2 is what I'm thinking. I've read all I can on here about LC-1, LM-1, Zeit, etc, but dont see anyone using the new one.
Stop me, please
Stop me, please
I was going to start a very similar thread.... so maybe I can jump on this one?
I've found a lot of WBO2 information, but nothing that really identifies which the best one to use on our cars...
Which Wideband is most popular, and why?
Honestly you can't go wrong with any of them, just think about what features you want and find one with it.
I personally use the AEM one, they are very widely used among all car make and models. The o2 sensors are reasonably priced for replacement (and you WILL have to replace them all eventually) and it has 2 outputs, an analog 0-5v and a serial 0-1v. This enables you to send the WB O2 output to whatever you have to output it to, like a piggy back controller, or what have you. Also the gauge can be switched to read out lambda and has replaceable faces for color and for AFR/lambda. This means if you switch to e85 you can just use the lambda to monitor your AFR's since lambda is the actual readout from the O2 sensor, and the AFR is calculated using that and assuming you're using gasoline on most O2 sensors.
They are also very reasonably priced and simple to install since the gauge and controller are all in one.
That's just my take on it, however. I do recommend if you're going to have one, to at least have a read out somewhere easily read while driving.
its a matter of what you want i got the lm-1 so i could box the gauge in on my laptop on the tunerpro software screen. pretty sad they are all just a shi**y v dub 02. at least most of them are. lm-1 new on ebay runs 220 shipped thats software sensor bung(lol) plenty of wiring module display box.
I've got to bring this thread back up... is there really NO feedback on RL from LM-2 owners? I've got a an AEM UEGO to install, but I'm thinking about selling it (NIB) and going with an LM-2 instead. Seems like it does quite a bit more, plus logs for future playback... Opinions? Is it any good?
Professional Hoon
I've got an LM-2 installed with mine. good unit, good display. I've got mine hooked up to my rpm, boost & tps. i used the tach sig from the motronic unit but it didn't want to read anything past 5000 rpm so i've used another signal from the fues box but havn't tested it yet.
so far the Pros and cons are:
Pros:
will show up to 4 signals on display,
show a line graph of any signal you choose
record and play back data logs on the hand controller
stores data logs on a SD card that will go straight into your laptop and viewed on the program that comes with it.
expandable to a LMA-3 (auxbox) with more signal inputs, havnt read much about that. not sure how it will display it on the LM-2 though.
Cons:
screen displays "rpm" "afr" but for the other 4 5v inputs only displays "0-5v" or "0-100%"
thats all i can think of.
I like it, easy to use. i placed mine on the wind screen, i made my own holder for it but recomend to but the holder that innovate sell.
Pros:
Cons:
Professional Hoon
Oh and i forgot to add, when you view the data logging on your laptop because it only shows 0-5v on the LM-2 you can change what it says on the computer,
and it also has two 0-5v outputs for a afr (narrow or wide band) output to talk to the computer so it knows what' going on or you can trick it by making it think its running lean to richen up the mixture, depends how advance you want to go with it.
Here's a quick image from a data log run i first installed it with only AFR, RPM & Boost inputs where i had to configure the input to data, which is easy if you buy an MAP sensor it should come with a data sheet where 0.01v = x and 5v= x
