Sport Edition Cup 4
#121
OK rookie "wheel spacer" question: Do the spacers you used with these rims mount on top of the factory spacer (that bolts to the hub), or did you remove the factory spacer and remount with longer bolts directly through the hub and out through the wheel ?
I suppose a pic would help answer my question, so if anyone has one please post.
Thanks !
Thanks !
#123
ps
running 9's all around
#125
#130
Are the tire max sizes different from the 951 and the 944? I have a 83 944 and was thinking about running the 17/9 in the back with the 17/7.5 in the front with no spacers but I don't know if I can do that. I heard that the rim sizing is different from the 951 and 944 but I just want to be sure it will fit.
#131
did anyone put these rims on a 78-79 928? any issues? spacers needed?
also - where would one order the centercaps at?
i think i want to put these on mine - seem like a heckuva deal - and exactly the kind of "freshening up" over the old dial rims that i'm looking for...
i'll probably put Toyos on em - my uncle is a wholesale tire guy and he carries Toyos, Bridgestone, Firestone, Maxxis, etc.
If any of you Denver folks need tires - I can set you up with his warehouse. They do mount and balance - but only by appointment.
#133
I just got my 944S and am looking at the Cup 4's. The original phone dials are very faded at in need of refinishing. Quick question: Would spacers on the rear wheels cause the tires to rub against the fenders?
#134
#135
