Euro Bumper Pics
#46
I took mine a small step further and built 2 more small brackets to help brace the bottom side so the bumper does not wiggle at all.
#47
Much TANKS!
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#48
back from death.... I am trying to find the part number of the rear rubber pad for the 951. I only managed to find the non turbo version.
here is a pic
http://www.rosepassion.com/en/cat/po...oulding/P40369
here is a pic
#52
According to 944online:
THE TURBO/S2 TYPE IS THICK AND HAS A CERTAIN NUMBER OF MOUNTING BOLTS THAT ARE EVENLY SPACED -THE NON TURBO/S2 TYPE IS THINNER AND HAS A DIFFERENT NUMBER OF MOUNTING BOLTS THAT ARE SPACED DIFFERENTLY
#53
951 bumper has tow hook provision with flap in it, it screws in to right bumper mount, na bumper doesn't have this because tow hook provision is in chasis under bumper's right side. It has a small cutaway in that location.
#54
J
#55
According to Euro PET the turbo version is:
951 505 069 00 Protective Moulding (black rub strip)
951 505 346 00 Cover Towing Lug (cover for tow hook)
#56
#57
#58
You are correct. The one I had was the NA bumper pad but the bumper itself is a Turbo bumper. I wasn;t planning to use the pad either way.
#59
At the end I ordered the parts from a P dealer's online page. The bumper, mountings brackets, rubber molding and cover towing lug arrived in 4 days at almost the same price that buying used at Ebay.
The $14.95 flat shipping rate was reason of going new instead Ebay.
Thanks all for your help.
