Build your own ITB's
Those would be fun to play around with although I'd like the injectors to be on or closer to the head base plate rather then part of the TBs. These would be nice to weld onto the stock baseplate and use the injectors holes in each TB as a secondary while keeping the main injectors in the stock location....
I did a little research on the website last night, the ITBs don't come pre-drilled for injectors, so you could conceivably re-use the stock intake runners and fab up connections for the TBs. But then you'd have to come up with a different system for the vacuum lines. Just for a set of 4 ITBs they want $1000, and that's a pretty steep buy in for something that will still need a lot of fabrication work. But I'd love to see someone take the plunge and do it. If I wasn't already spending a fortune on replacement parts and powder coating for my 951 rebuild, I would SERIOUSLY consider the ITB route...
