450 hp 3.0l 16V N/A??
Location: Encinitas, ca PCA National DE instructor PCA San Diego chief driving instructor
Agreed, its usually very expensive race engines that make 150hp/liter. Not impossible though
The limiting factor for a 3L 4 cylinder car engine is going to be RPM. At 88mm stroke the 3.0 would be at 25 m/s at 8500 rpm.
1L sport bikes can turn a whole lot faster.
Yeah bikes arent the same when they are making that power at 17k rpm...
If you search on youtube pocono 944, thats the car ive seen that makes 300bhp and revs to 9k rpm.
Former Vendor
This car is probably one of the most highly developed 944s in the world:
http://www.raetech.com/944_Racing/944.php
According to this post from the builder it's a 2.5 16V making 300+ @ 8000 RPM
http://forums.pelicanparts.com/showp...18&postcount=7
Being generous and just extrapolating 20% out to 3.0 you get 360+. In reality you'd probably get the 10% increase going out to the 2.7 bore, but you may get 0 HP going the longer stroke. Any displacement gain from longer stroke could well be offset by reduced rpm's because of the stroke length. Going to a longer stroke and 8000+ seems unlikely - I'm too lazy to figure out the piston speeds but they'd be pretty high.
Some details has been leaked about the engine mentioned in title, and it's turning to be based on a S2 block...apparently displacement is between 3.2 and 3.6l and the head is milled from billet, so in that case it's a totally different animal...
I'll keep you posted if facts comes out.
There was an article in Excellence ( #175, August 2009 ) about this racer, the claimed power was 350hv @ 8500 rpm. 140 hv/l.
If it is actually 3.2l and a true one off custom engine then it seems like 450 HP is possible. The specs could be something like:
106 mm bore x 91 mm stroke = 3.2l
91 mm @ 8500 rpm = 25.8 m/s - which seems possible with a custom crank.
So 3.2l x 140 hp/l = 448 HP
I don't know what power it made and haven't seen it raced it many many years, but this S2 (924 chassis with S2 mill, iirc) is still ones of the fastest production based cars i've ever seen at Summit Point. Only picture i have is post wreck at this DE. It had carbs instead of FI, (i think). ITB's for sure. I'd believe it if someone told me 400hp, easy. Driver/builder was a guy named Mike Mount, iirc
I had a mate who was talking to a girl at a bar in Tehran who's step brothers uncle's dog was told by the neighbours burmese cat that it had heard of a 400+ hp N/A 944. the cat was told by the vet and the vet was told by his wife who heard it from santa. i verified the story to be true when i asked santa at christmas when he visited. So it must be true
Not enough valve area. For comparison, I did consulting type of some work for an acquaintence with a 3.0L 6 cylinder. It had 12 33mm valves, for a total valve area of 103 square cm's. It made 306 at the wheels, so figure 350 at the crank. Race fuel, 13.5:1 CR. The new engine isn't done, yet, I'm thinking we may pick up 25-ish HP, and we put 34mm valves in it.
The S2 has 37mm valves, total area 86 square cm. The 968 has 39mm valves, 96 square cm. While the Porsche is over square versus the BMW being undersquare, which will help, even with 39mm valves, it is still shy of the valve area for one that may see 375 if we're lucky.
I just don't see it being anywhere near 450 horsepower. A 3.0L may do it, but it would take probably 10-11,000 RPM, and much bigger valves. Very unlikely, IMHO, that a 4 cylinder could do it.
Former Vendor
King, for general info, is there a common formula for counting theoretical max power output in relation to valve size?
My past 8V engine had 4x 48mm inlet valves = 72 cm2 valve area.
I never said impossible. Just very expensive.
http://www.pumaracing.co.uk/PP03.htm
He uses a mulitplier to determine power potential. His standard multiplier for 4V heads is 10% but then when calculating for a "F1" engine he uses a multiplier of 25%.
The formulas show NASCAR engines generate power using a 20% multiplier - and that's with 2V heads. I checked a few other high hp engines and they generate anywhere between 15-20%.
To generate 450 HP using a mulitplier of 15% you'd need around 43mm valves. I checked a few engines with 106mm bores and they can fit 43+ mm valves. It may not be possible to modify the stock heads enough to fit the big valves - that would be a reason to use a custom billet head.
All that will give you, though, is RPM at peak power. To figure out a good power number, you'd need to know the thermal efficiency (better known as ISAC - or Indicated Specific Air Consumption) and the mechanical efficiency (FMEP - friction mean effective pressure).
Those are rules of thumb, though. I did a lot of analysis on that engine I referenced, which is why I felt good using it as a baseline.
FWIW some of you guys are way high on your rpm numbers for 1 liter sportbikes. Most modern sport bikes hit peak power more around 12-13k not 17k. For example Yamaha claims 180 crank hp @ 12.5k for a998cc displacment.
How about a 600 though? Either way it will take high rpms to make 450bhp out of a 3 liter engine hah
