Who will be happy with 300-320rwhp?
#77
Lower backpressure will mean lower egt, right? High egt's are a problem on a stock 26/8 when you increase the boost pressure. It would be very interesting to know the backpressure on your cheater 26/8 vs stock. (I know your stage 2/3 is exellent when it comes to backpressure/ egt).
#78
If you ever pull your turbo, we can modify it a bit to handle a bit more flow for less backpressure.
#79
#80
Following along Greg's thoughts... would you be able (& willing) to mod a K27/6 or /8 with your cheater type mods? This would be for someone looking for more power when your stage 2/3 are no longer available.
Just curious and putting it out there as I have the real deal waiting to go on... I'm actually kind of surprised no one's asked yet. Cheers!
#81
I tried posting this last night after Greg's question, but for some reason it did not take...
I'm not a big fan of the K27/6 mainly because of the back pressure issue. A few things can be done to improve it, but not to expect miracles.
The K27/8 is ok, just a bit laggy for my taste.
At this point, I want to see how well the Stealth kit does. As far as reworking K27/6 or K27/8 I'll have to think about it, it may not make much sense $ wise.
#83
The Stage 2 is in a different league all together. The cheater setup has a target of 300-320rwhp.. The Stage 2 is 380-400rwhp, a totally different game. However the Stage 2 as we know it will soon become history (I have 1 left that I have been holding for a customer that now wants to go bigger).
The cheater can be used with stock injectors, but will need a 3bar FPR.
Feel free to pm me, if the info is sensitive.
#84
Well once you use the K27 compressor, it's no longer stealth as the compressor housing is larger (2.75" inlet). The stealth or cheater turbo looks identical to the stock K26 from the outside.
BTW, still grinning every time I drive now with your MAF setup! Wanting very badly to get the stage 2 on there, but am forcing myself to sort a few more things first.
Take it easy!
