Is my trans a 951 trans?
Old 08-16-2009, 01:55 PM
  #61
CarbonRevo
CarbonRevo's Avatar
A Stock 951 certainly has the power to hit 145-150 in 4th. Granted you need a raised rev limit to do so, which usually means a chipped car. My car only had chips when I dynoed at 240/250.
I had 255/40/17 Kuhmos on my 993 Cup II's and I wasn't thinking those tires would give me a 195mph top speed. I had done the math and I got about 183mph~. I was pretty certain at around 3500rpm in 5th, my car was doing 90.
You for sure need the long fifth gear to get a 951 close to 200mph.
Old 08-17-2009, 01:26 AM
  #62
alxdgr8
alxdgr8's Avatar
Haven't looked at the number yet (probably will this coming weekend) but I'm pretty sure it's an S2 and it is for sure LSD. I think I'll hold on to it though
Old 08-17-2009, 12:47 PM
  #63
V2Rocket
Rainman
V2Rocket's Avatar
about 76 mph in 4th gear at 3400rpm
people say the vdo is optimistic but i have tested mine against a known good car and it is within like +/-3 mph
Old 08-17-2009, 01:09 PM
  #64
MM951
MM951's Avatar
FWIW, up to 100mph my OEM speedo is dead nuts on. I have 225/45/17 255/40/17 tires and this is with both GPS and those stupid "here is your speed signs" that do nothing other than encourage you to max them out
Old 08-17-2009, 01:49 PM
  #65
Darwantae951
Darwantae951's Avatar
According to my GPS (and I don't think it's inaccurate) when my speedo shows 100 I'm actually at 117...anyone know of any companies that can recalibrate them or can that even be done?
I'm running 255/40-17s, a rather common size. Anyone else have that much of an error?
Old 08-17-2009, 01:53 PM
  #66
alxdgr8
alxdgr8's Avatar
Same here, mine is within 2mph or so verified by GPS.
Old 08-17-2009, 06:06 PM
  #67
bearone
bearone's Avatar
mine's 4-5 low @ 80 confirmed with gps.
87951
95sl320 dd
Old 08-18-2009, 12:46 AM
  #68
V2Rocket
Rainman
V2Rocket's Avatar
my high score is 83 in a 35!
Old 08-18-2009, 11:34 AM
  #69
bearone
bearone's Avatar
same size tires on the back and like most folks i show 4-5 low @, 80 where you're showing 17% high @ 100.
i've got a speedo place in phx, doesn't help you, that puts you on rollers and runs actual and indicated up to 80 and provides a card that some folks use, when captured for speeding, when going to court.
87951
95sl320 dd
Old 08-18-2009, 12:25 PM
  #70
Darwantae951
87951
95sl320 dd
My driving style is fairly reserved on the street. I rarely get tickets and when I do it's usually for not using a turn signal in the turn lane...
I just want my speedometer to read accurately!
Old 12-09-2009, 06:28 PM
  #71
alxdgr8
alxdgr8's Avatar
Finally got under the car with some playdough and confirmed it is an AOT (S2 LSD) trans
Old 12-09-2009, 07:03 PM
  #72
CarbonRevo
CarbonRevo's Avatar
Bastard...
Old 12-09-2009, 07:31 PM
  #73
Bill
Bill's Avatar
you'll never pull 7k in 5th.
My Guru chip has a raised redline to 7,000 rpm. I have 335 rwhp (about 390 crank) and can hit the rev limiter in 5th at will. In fact the motor is still pulling.
Old 12-09-2009, 08:45 PM
  #74
alxdgr8
alxdgr8's Avatar
Now having this confirmed I'm going to have to scout around some more and see if there's anything I can find different/special...
Going to check my block and see if the serial matches the car.
Edit:
Had Suncoast decode my VIN:
Vehicle-Ident.-Number (VIN)
xxxxxxxxxxxxxxxxxxxxxx
Sales Type
951352
Model Year
1987
Block Flag
Blocking Date
Engine Type
M44/51
engine number
45H03924
Gearbox Type
G016S
transmission serial number
5R11037
Tire Code
PIRE
General information
Invoice Date 1
1987-05-06
Invoice Date 2
1987-04-24
Number of "Z" Orders
0
Country Equipment
C03
Trading Partner
4300020
Commission Number
059031
Body specifications
Exterior Paint Color
P1P1
Alphine White / Alphine White
Interior specifications
Interior Trim
LT
Interior Trim
Black Interior-Partial Leather
Interior Equipment Code
KL Leatherette
Seat Combination Number
ATG
Seat Cushion Material
LED Leather
Seat Side Support Material
LE Leather
Seat Back Material
KL Leatherette
Carpet Color Code
5FV
Warranty data
New vehicle warranty
31.Aug.1987 - 31.Aug.1989
Emission warranty
31.Aug.1989 - 31.Aug.1994
Varnish warranty
31.Aug.1989 - 31.Aug.1990
Corrosion warranty
31.Aug.1990 - 31.Aug.1997
Campaigns
Scope Status
AK03 1
MNR Type Description
220 341 414 454 650 946
220 F Limited Slip Differential
341 F Central Locking System
414 F Transmission Oil Cooler
454 F Cruise Control
650 F Electric Sliding Sunroof
946 F Partial Leather Seats Front
Old 12-09-2009, 08:55 PM
  #75
V2Rocket
Rainman
V2Rocket's Avatar
ill trade you my turbo trans w cooler AND an NA trans too lol
Quick Reply: Is my trans a 951 trans?
