Am I going to nuke something?
#31
Rainman
$280 for what? just the air to water...what about the water to air part? the piping, the pumps? Sensors or are you going to run it wide open all the time?
If you are clever enough to desginadn fabricate an air to water to air system then you should be ableot buy a decent used shortblock and refresh it for way under $1k, closer to $500 if you do it yourself...
i rebuilt my NA engine at a cost of around $2000, what goes under your definition of "refresh"?
#32
If that is the case then he can throw a smaller pulley on. I installed my intercooler after I had already been running over 15 psi. I didn't really notice a drop. It was nice no longer having to worry about the methanol injection. One thing to remember about the roots blower is that they put out a lot of heat. At 12 psi I was seeing close to 300 degree AIT.
I like the setup using the mafterburner, that sounds great.
#33
With regard to my Corvair, I ll be happy to share information on my car.
#35
I'm a proponent of W2A IC's and see no problem with running one. If done properly, then there should be no problem with heatsoak or heat buildup in the water system. Geo and Honda radiators are fairly compact and work great for the purpose of cooling things down. I've heard of them being used on other cars. If it's good enough to stabilize engine temps, then I'm CERTAIN that it will be able to keep boost cool.
The other thing to keep in mind is the capacity of the system. I recommend having the pump flow from a reservoir, into an HE and then into the intercooler. Even a small-ish (but not tiny) reservoir will help. The more capacity, the better heat control.
Don't mess with those ***** HE's with the kits that are available. Get a small car radiator, plug off the ports, then tap for the AN fittings. It'll work.
I've done some work with A2W before and intend on making it work with my 951 when I start getting free cash in. [/pedestal]
I don't THINK that you'll run into a problem with nuking anything, but I would be prudent. Watch your gauges like a hawk. You should be alright on 10 pounds. Buddy with an A2W cooled MP62 Hyundai V6 tiburon, with 11:1 compression on 8 pounds of boost ran just fine for the longest time. Great power figures, and the HP line on his graph was still rising when he hit ignition-cut. 280whp without functional meth injection. Your stock compression should be fine.
I've got faith in your build!
#36
I'm sorta struggling to read this right. On one hand it sounds like you're going to an awful lot of time, trouble and I'm betting more money than you're bargaining for to do something that you want to be able to reverse engineer so that you could possibly sell it as a stock car? Then, when you can get motors, parts, and work done so cheap in the US you're passing on the 951 (or parts of) idea?
Not knocking your ingenuity or perspicacity Spencer but I hope you're going to be happy after all this with 250hp or whatever it is you're imagining? I'm happy to see someone do something out of the norm and wish you success.
#37
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
In keeping with the DIY and ‘inexpensive’ direction of this thread – all you need to refresh and good used 951 shortblock is to replace the rod bearing and gaskets. If the rod bearings look decent then leave the mains alone. Sure, it would be ideal to go through the whole motor and replace all sorts of stuff…but you did want to take the ‘economical’ way.
If you are picking the A2W because you think its cheaper then I think you might have a surprise coming, If you are doing it for the challenge then go for it.
BTW – ignition timing is the key to getting any boosted engine to live.
#39
Full kit for $280? OK, thats pretty cheap - but you do have quite a bit of fabricating to do - especially since you don't want to make any sheet metal mods.
Just want to back you up on the timing comment. My J&S Safeguard is a life saver, I keep an eye on the monitor, it retards my timing if knock is detected, I can also preset timing retard per pound of boost.
#40
Rainman
i understand the desire to be making 300whp and i certainly would like that but when the time comes for me to play with that then i will buy a 951. but for now mr NA is going to be getting some breathing assistance and id honestly be happy if i could break 200 at the wheels. the car just needs more pickup from a dig (especially with the 951 gearbox, great on the highway but off lights it is slowwww). i do realize that this is the wrong car to start with for mega power goals but that is not what im looking for with this project.
#41
Rainman
and yes ive thought about a reservoir and im trying to devise a place to mount such a thing...maybe over where the cruise control unit used to be, or where the PS reservoir is not being used..
#42
Rainman
what octane?
and do you guys think that the DME FQS is enough for AFR tuning? if not, what can i use short of maxtune/ostrich (which would probably be ideal)? according to frwilk there is only so much adjustment for fueling/timing, either pulling 3% fuel or adding 3 or 6% fuel, and pulling ~3* timing.
#43
Another idea in regards to intercooling; you could run just a straight water/methanol injection system. Depending on the amount injected and the ratio between water and methanol you can easily take out a good 100 degrees F of heat with zero pressure drop. No complexity of water/air IC, cheap, and you you don't have to squeeze in a 951 IC.
#44
Rainman
#45
what octane?
