CAR FIRE PICTURES POST THEM HERE
Posts like this got me scared, I had replaced the fuel and return line but not the rail to dampener line cuz it looked OK..... I went ahead and replaced it yesterday and MAN !!! It looked OK from the top but was all cracked and ready to leak on the bottom.
Glad I replaced it.
Glad I replaced it.
Glad I replaced it.
Glad I replaced it.
Fuel Line
Fuel Rail
to Diaphragm Damper
944 110 413 02 GENUINE PORSCHE
yeah ive rarely seen the fuel lines leak- our 924s had a big bubble in the line though- usually that little jumper is what lights em up. I always replace them whenever i buy a car. $80 at porsche is worth it- i believe rennbay has something for them too.
Lazer Beam Shooter
No it isnt. The pre 85.5 N/as had a different fuel rail setup with the damper and regulator both located at the back of the fuel rail.
After 85.5 the dampner was moved to the front of the fuel rail which included the troublesome damper line. So the early cars dont have this problem.
Safety recalls are done for free on cars usually because of the huge liability and lawsuits that could come if they arent done. If an auto maker makes a car and it has a problem and people start dying in fires due to a manufacturing error, that will cost the company big big bucks in court.
Here is the info on this recall:
Recall Date
APR 02, 1990
Model Affected
PORSCHE 944
Description
THE HOSE MATERIAL USED IN THE SHORT SECTION OF THE HIGH PRESSURE FUEL LINE HOSE, BETWEEN THE FUEL RAIL AND FUEL PRESSURE REGULATOR, IS SUBJECT TO HARDENING, AND COULD CAUSE FUEL LEAKS BETWEEN THE HOSE AND THE METAL PIPE FITTINGS.
Consequence
FUEL LEAKS COULD IGNITE ON THE HOT EXHAUST SYSTEM, OR ANY OTHER SOURCE OF IGNITION, RESULTING IN AN ENGINE COMPARTMENT FIRE.
Remedy
REPLACE FUEL LINE HOSE WITH HOSES MADE OF IMPROVED MATERIAL.
Potential Units Affected
53427
Notes
PORSCHE CARS N.A. INC.
Recall Date
APR 02, 1990
Model Affected
PORSCHE 944
Description
Consequence
Remedy
53427
Notes
Recall Date
APR 02, 1990
Model Affected
PORSCHE 944
Description
Consequence
Remedy
53427
Notes
Recall Date
APR 02, 1990
Model Affected
PORSCHE 944
Description
Consequence
Remedy
53427
Notes
Thanks for that
The previous owner has this recall letter inside the Porsche Manuel. I assume he had the recall done. i will call though just in case. However, Porsche replaces the jumper with a new improved one? if that's the case is their two part numbers for the original and updated one? If not, then do you think there is a recommended milage on a new jumper line before it needs to be replaced again?
Wax On, Wax Off
Yeah, I was doing something or other with the exhaust on my turbo, and just happened to look at the jumper line... out the corner of my eye... and it had a large bubble, it looked damn near ready to pop on me... the 2nd closest dealer had one in stock, and they offered a PCA discount so I got it for $60 something...
Lazer Beam Shooter
1989-91 944's were replaced with a line made of a different material. However this doesnt solve the problem as even the newer material will get old and crack. Since this material is replaced well within a reasonable safety standard, there is no recall on this line for these years.
The old part number was 944.110.413.01 this part number was superseded to 944.110.413.02. The old part number virtually doesnt exist any more today because it was superseded while the 944's were still in production.
Lazer Beam Shooter
Good stuff, just wanted to be sure since Im running a 044 pump I know that there will be more pressure in the fuel system and all it takes is one weak link.
